Roof Rails?
Roof Rails?
Hey I've done some searching on the forum for the answer to this but cant find it anywhere. What model car's roof rails fit a 6th Gen, I've found a set off of a 01 GTP could someone let me know if they will fit thanks alot for any info, if its in a post somewhere and missed it I apologize.
Yeah I have a warehouse furnace in a 20x20 garage, 35 degrees C, in a matter of minutes so that wont be an issue but thanks for the heads up. Do you know if you have to remove the molding that is there before install or install right over them?
Yeah remove the molding.
There is a how to installs them in the how to section.
*edit* found it
https://montecarloforum.com/forum/sh...ad.php?t=21345
*edit* found it
When you remove and clean up the original molding slots, make sure you put the roof rails in without any sticky tape so you can see if you need to bend the rails.
Mine needed to be bent so I had to sit them out in the sun for a while then "mold" them with my hands.
