RIMS
Old Dec 29, 2006 | 01:21 AM
stuart's Avatar
Default RIMS
Hello i was wondering about rims made out of aluminum is this like a weak metal and are most rims made out of aluminum cause i thought it was a kind of steel or somthing but i dont know much on the subject so i was hoping i could get advice on these rims thanks
Old Dec 29, 2006 | 02:29 AM
djhixter's Avatar
Default RE: RIMS
aluminum wheels have been very popular in the last 10-15 years. one of the reasons is they are lightweight and have some style to them. compared to steel wheels, they are about as strong as steel as far as holding the weight of the vehicle. they are just as fragile when it comes to potholes and things like that. they do however, will most likely break where a steel wheel will bend. some cleanup on aluminum whees can be a real pain the the a$$. brake dust pits the aluminum badly if you don't clean them often. on that same token, they are more prone to rim leaks due to corrosion build up between the tire bead and the rim. being a service manager, when we sell rims we stess the cleanup of aftermarket wheels because they don't hold up as well in the wintertime when salt if used to clean-up the roads. if you purchase a set of aftermarket wheels i recommend (like we do at our shop) to install your factory wheels to preserve your new aftermarket wheels so they look there best. hope this helped you out.
Old Dec 29, 2006 | 10:19 AM
wiz kidd's Avatar
Default RE: RIMS
yah, really the only advantage aluminumumum wheels have over steel wheels is that they're lighter, however a lot of the manufacturers are changing from chrome plated steel to chrome plated aluminumumumumumumum
Old Dec 29, 2006 | 05:00 PM
stuart's Avatar
Default RE: RIMS
Ok thanks very much, so overall they are ok tothink about buying just gotta keep them clean?
Old Dec 29, 2006 | 05:58 PM
wiz kidd's Avatar
Default RE: RIMS
yup, exactly and watch out for pot holes lol
Old Dec 30, 2006 | 03:32 PM
stuart's Avatar
Default RE: RIMS
Ok thanks guys very much 4 your help
Old Dec 30, 2006 | 10:24 PM
benhillzone3's Avatar
Default RE: RIMS
yeah aluminum is more used by ricers cause they are lightweight
Old Dec 31, 2006 | 12:27 AM
The Black Machine 29's Avatar
Default RE: RIMS
yeh my rims are steel... they cut races by car lengths tho lol
Floydcarlo
May 13, 2014 09:23 AM
05MonteLS
Mar 25, 2014 09:28 PM
Randdady
Mar 23, 2011 08:16 AM
05MonteLS
Dec 3, 2010 09:00 AM
irulesoha
Sep 21, 2010 10:08 AM
