2nd Gen ('73-'77): Removing rear seats doubt
Old May 14, 2017 | 10:02 PM
AngelUtiel's Avatar
Post Removing rear seats doubt
Dear all,
I just started on this forum. I'm restoring a Monte Carlo 77.
I'm almost complete with the mechanical side and moving into the interiors. I have removed all interiors from the rear part (plastics and horizontal seat) but I'm struggling with removing the vertical part of the back seat. It is somehow like blocked and I'm not able to remove it. I didn't find any bolt to remove, I believe it is set by pressure through some guides but I'm a bit concerned of pushing too much.
Any help or guide to remove it?
Regards and thanks in advanced
Angel
Old May 15, 2017 | 06:50 AM
SOLVED: Remove back seat 1977 monte carlo - Fixya
Hope it helps..
QUOTED from that page,
"To remove the rear seat you will need to push down and back and then pull up, this needs to be done on each side of the seat to remove it and reverse to install the seat, good luck hope this is helpful."
