Rear Wing Removal.
Old 11-15-2007 | 01:50 AM
Twisted_Metal's Avatar
5 Year Member1 Year Member
Default Rear Wing Removal.
Hello guys, I'm having a little problem. Just how much horsepower will I loose if I remove my rear wing? Okay, okay just playing about that part.[8D] Seriously though I'm tired of wiping down my trunk everytime I wash and get my car waxed because the wing holds water after a wash. I want to remove it all together and rid the mess it leaves on the lower part of my trunk. It always leaves these nasty white drip lines and my car is black so it really shows and looks yucky. Basically what I really want to know is how hard is it to remove and what should I use to fill the holes in afterwards, or do you guys even reccomend it?
Old 11-15-2007 | 04:50 AM
RocknSS04's Avatar
Default RE: Rear Wing Removal.
It will take a repaint job, or, you can try to locate a lid without holes, used, and maybe even in black, as it's a popular color. You could also look for a lid with the vertical spoiler, like mine. Still some water holding issues, tho, if that's what you are trying to eliminate.
Old 11-15-2007 | 07:25 AM
06MonteSS's Avatar
do what I do... use an air compressor and blow the water out from under it...
I go around my whole car with it... all the seams, door handles, wheels/tires, grill, inside the gas filler door, etc etc...
that way there's a lot less water to dry off from the door jambs, under the trunk, under the hood, etc etc...
Old 11-15-2007 | 08:34 AM
2 quick4u's Avatar
I use one of those leaf blowers and it removes all the water without having to use a drying towel. then you can go and wax it without having to wait to you get it all outfrom the cracks in the door jams..everyone has there own littles ways ...Thats mine....
Old 11-15-2007 | 01:40 PM
Cowboy6622's Avatar
i don't think your car would look right at all without that spoiler... i say take the good with the bad.
Old 11-15-2007 | 04:44 PM
rj's Avatar
rj
(my $0.02 worth)
The '00 - '07 Montes look down right ugly without a rear spoiler.
One thing you could try. Clear silicone the entire bottom edge of the spoiler. This will mean removing then re-installing the spoiler to get to the bottom edge but the silicone will prevent water and dirt from getting under the spoiler.
I did it to the rear spolier on my '86 LS Monte year ago. It's still holding up just fine.
Old 11-15-2007 | 07:40 PM
I agree with rj. 2000 up Montes don't look right without a spoiler.
There's a few around town here, and the back end looks weird withouta spoiler.
Old 11-19-2007 | 12:49 AM
Well just for fun I took the rear wing off and gosh! darnit and I lost about 50 horespower[X(]!
You guys were right it doesn't look the same without it installed ...
I'll leave it on and seal it with some silicone sealer ..
Old 11-19-2007 | 07:21 AM
Hey if spoilers add 50 horses, I need to get on ebay, buy 4 or 5 more spoilers, and bolt 'em on. [sm=icon_rofl.gif]
joe053068
12-22-2010 07:44 PM
fastback4
11-29-2008 11:28 AM
Cloud_Master
02-26-2008 08:30 PM
04MonteLS
10-14-2006 03:37 AM
malletboy
05-09-2006 03:39 PM
Quick Reply: Rear Wing Removal.
