Radio Antenna Question
Old Sep 13, 2007 | 09:37 PM
Twisted_Metal's Avatar
5 Year Member1 Year Member
Default Radio Antenna Question
Can anyone locate the radio antenna on the 06-07 Monte Carlo? Is it the little bubble thingy on the dashboard .... ?
Old Sep 13, 2007 | 10:08 PM
FlynhghR's Avatar
Default RE: Radio Antenna Question
Nope the bubble is actually the light sensor... Cover it up a spell, your car will turn on regular headlights and dim interior stuff thinking it's dark out.
The antenna is (from what I understand) either in the front, or the rear glass.
Old Sep 14, 2007 | 04:37 AM
HyperFox's Avatar
Im almost 100% sure the FM antenna is located in the rear of the car, on the back window, running from left to right. I belive the one on the windshield is the Keylees entry antennas for those who get the extended range key fobs. (The ones that have factory remote start) Im still working on a solution to fix up the antennas to increase the range because its no where near the 200 ft range.
Old Sep 14, 2007 | 07:19 AM
Mrrench's Avatar
Yes
The radio ant. is in the rear glass
If you have the remote problem fixed, they unhook the ant on the windshield and add an ant in the left front plier
Old Sep 14, 2007 | 10:02 AM
cain45's Avatar
The radio antenna on all 06-07 Montes are in the rear window.
Old Sep 14, 2007 | 12:54 PM
FlynhghR's Avatar
Thanks for the info Mike, another question.. is this something that can be removed since it's not useful in my car any longer? (had it fixed, should have the antenna in the A pillar) I mean, if it's even visible.
Old Sep 14, 2007 | 12:58 PM
06MonteSS's Avatar
it's visible... it's that little black connector in the top left corner of the windshield... don't think you can yank it out - it goes into the glass - that's why the TSB says to leave.. "for aesthetic reasons"
Old Sep 14, 2007 | 09:47 PM
okay thanks, as for the back window being where the antenna is that wouldn't be a bad idea my dad's '75 impala has the antenna there ...
Greeny
Mar 20, 2023 02:20 PM
70monte1
Sep 19, 2010 09:43 PM
Yellow_Monte
Jan 28, 2008 02:50 PM
spills
Dec 2, 2006 07:25 AM
rrobert05
Jul 5, 2006 12:03 AM
