quick question
Old Dec 9, 2009 | 01:00 PM
monte 18's Avatar
Default quick question
how can i reset the control lights for the low ties pressure and such with an after market head unit? if i can
Old Dec 9, 2009 | 01:41 PM
MAMONTE's Avatar
I'm pretty sure you must have the factory head unit in 6th gens in order to reset everything. The only thing that I know of that has an alternate way of resetting is the oil life. You can reset the oil life by pressing the gas pedal down 3 times in a row.
Some members have had there factory head unit mounted in the trunk so that they could still use it for resetting features, but also still but an aftermarket deck.
Old Dec 9, 2009 | 02:28 PM
Wilco's Avatar
Check here!
Old Dec 10, 2009 | 07:59 AM
monte 18's Avatar
thanks for the advice but i think gm should have thought a little bit more about that(how did you mount the old one in the trunk?)
Old Dec 10, 2009 | 10:38 AM
jaws2008's Avatar
GOT SPL
turn the ignition to on.
turn on the parking light on then off---repeat a total of 3 times
the tire monitors will now be reset---you do not need the stock head unit for this.
Old Dec 10, 2009 | 11:09 AM
Wilco's Avatar
Using an adapter. they run about $20-$45 dollars depending who you buy it from. It comes with a long wire adapter that you can run into the trunk.
Check here!
Old Dec 10, 2009 | 12:52 PM
jaws2008's Avatar
GOT SPL
Check here!
Thanks for the link i have always been wanting to relocate mine but could never find the harness for it
Thanks
ckd
Jun 14, 2006 05:22 AM
TKay2000monte
Nov 13, 2005 12:46 AM
OC_Broo
Aug 22, 2005 02:54 AM
myride05
Feb 24, 2005 06:44 PM
pg2676
Feb 19, 2005 02:12 PM
