Problem with Fan/Blower Switch
Old Aug 17, 2010 | 08:54 PM
hillre48's Avatar
Red face Problem with Fan/Blower Switch
Hope all is well! I've a 2000 Monte Carlo LS (3.4) engine with 96,000 miles. I seem to be having a problem with the switch that control the blower motor. The switch has like five different setting (i.e, 1, 2, 3, 4, 5). The problem is that the switch only has one speed which is "5". Does this means that the switch is bad or what? Has anyone had this problem or is familiar with this problem? Are these difficult to replace? Thanks for any assistance! Take care!
Old Aug 17, 2010 | 09:20 PM
seems kinda familar with this..... I just did a a copy and paste from an old thread, hope it gives you some good info!
mnmtw
02. I lost fan blower on 1,2,&3. 4&5 are fine.
I thought it might be a fuse but I haven't found anything blown. Any help Please. Thanks
RocknSS04
You have a blown resistor block. It's way up under the dash on the passenger side. Above the heater box, I believe. Make sure you get the newer heavy duty version, encased in epoxy when you get one.About $35 at the dealer. Don't hold me to that. It'e been more than a few years now.
__________________
My '04 Intimidator SS MCF Photo AlbumMy RocknSS04 CarDomain Site
Old Aug 17, 2010 | 10:49 PM
labnjab's Avatar
+1 to the resistor, I've replaced dozens in gm. Sometimes you need to replace the connector as well, but thats close to $100
Old Aug 18, 2010 | 08:20 AM
hillre48's Avatar
Red face
Thanks for responding! Need more details! What exactly does +1 to the resistor means? Where is it located? What is the cost?
Old Aug 18, 2010 | 09:15 AM
labnjab's Avatar
I was just agreeing that it was the resistor. I'm not sure exactly where its located on the monte, but on most vehicles its somewhere in the heater box on the passenger side. Its usually held in by 2 or 3 small bolts and usually has a 5 or 6 wire connector. IME on a lot of gm vehicles, the connector will melt to the resistor so you will need to replace both the connector and resistor, and both can be purchased at the dealer. The resistor is usually under $50 and the connector is close to $100
Old Aug 18, 2010 | 03:19 PM
hillre48's Avatar
Wink
Thanks, i hope i don't need the connector, (gosh)..........maybe i can find one at a junk yard).
Old Aug 19, 2010 | 10:35 AM
labnjab's Avatar
U may be able to get the connector from the junk yard, but 8 out of the last 10 gm resistors ive changed ( i work at a family owned garage) needed the harness so a junkyard one may be melted too. Most were on trucks and not cars so you may get lucky and not need it.
Old Aug 20, 2010 | 04:26 PM
hillre48's Avatar
Smile
FYI,
You were exactly correct; I replaced the blower motor resistor at cost of $28 at Auto Zone. What a job! Had to lay on my back the entire time. Also had to remove the blower motor. I would think GM could have found a better location to install that device. My back is still a little sore. I appreicate you help so much. If I had taken this vehicle to a dealership, i'm sure it would have costed me over $100. Take Care! I'm sure I will be back on here for more help in the future. I just posted another thread yesterday on reagarind a problem that I'm having with my ABS light being on all the time. See ya.................My fan is working ON all settings thank to you and this website).
mnmtw
RocknSS04
__________________
Old Aug 20, 2010 | 04:28 PM
hillre48's Avatar
Smile
Hi,
mnmtw
RocknSS04
__________________
Old Jul 17, 2019 | 09:18 PM
EnchantedK9's Avatar
Ok. So...Only had speeds 1,2,3,4 no 5. Changed Resistor. Still no 5. What now?
