Please help!!! want to install new amplifier.
Old Jun 4, 2017 | 12:42 AM
nutzz248's Avatar
Default Please help!!! want to install new amplifier.
Hi everyone!! My name is Mike I have a 2001 Monte carlo SS. I want to eliminate the stock amp and put in a aftermarket amp. I already put in aftermarket head unit. Is there any way I can use wires off of the wire harness going into the stock amp and put them into the aftermarket amp? I know you can get a harness to cancel out the stock amp but is there any way to use those wires? Thanks!
Old Jun 7, 2017 | 10:47 PM
I am not a car audio expert, but I don't see why you couldn't. The amp has Left/Right input wires direct from the head unit, plus ground, power and Left/Right/Front/Rear output wires.
I personally would shy away from cutting the wires and instead build a harness. GM used two different amps from '00-'05. One connector is the same as the radio connector and the other one is different depending on which model amp. You may need to pull pins from connectors to build a harness.
Google for the pin outs of your amp and that should help.
Old Jun 12, 2017 | 07:09 AM
Kenny Guido Temprano's Avatar
if you know anything about stereos, just run new wires. trust me, i tried disabling he stock amp and it was a wiring nightmare. just run new wire. it will save u a huge headache.
Old Jun 12, 2017 | 09:53 AM
I have a diagram around here from a long time ago where I labeled each wire coming out of the amp.. Id say its probably from 2010..
You need to at the very least, run new power and ground wires..
For some its easier to just run all the wires. For me, I used the stock wires and ran a new power and ground..
Old Jun 12, 2017 | 05:38 PM
nutzz248's Avatar
I ran new wires up to where the radio harness is but it is still playing off the radio. Does anyone know what the wire colors are coming off of the front 2 speakers before they get tied up with the radio harness?
Old Jun 13, 2017 | 04:34 PM
OK, I dug DEEEEP for my old wire write up.. If yours is like my old 02 ls the front two speakers are as follows,
Right front + light green - dark green
left front + tan kinda orange -grey
Each separate speaker has the + and - twisted together to avoid confusion in colors..
Hope this helps..
Old Jun 13, 2017 | 04:49 PM
nutzz248's Avatar
Hope this helps..
Awesome thank you. It's way to hot to mess with it today but I will be doing that as soon as it cools down within the next couple days. Thank you!!
