6th Gen ('00-'05): Oil Gauge / Pump
Old Jul 30, 2018 | 06:28 PM
TugBoat's Avatar
Default Oil Gauge / Pump
Need some more Help....... My '01 MC'SS ~ (130K Miles) . Low oil light has been on awhile. Even after New Oil change. Plenty of oil w/ Lucas. Today the wife was driving and she Happened to notice the Oil Gauge was at "0". (Yes I taught Her to LOOK at Gauges). I got home.... Checked OIL.... Good.... The gauge at Idle reads 1/4 Line at 2000 RPM Just under 3/4 Line. Holds steady at both.....? Any Ideas? Oil Pump? Sending / Pressure Unit? I did a search on here and found nothing...... So I guess..... ? Thanks for any Help.... Not sure I want to change a Oil Pump, Last I did was on a 327........ Thanks!
Old Jul 31, 2018 | 08:03 AM
You may be in luck depending on how you wanna look at it.. It sounds like the gauge is bad.. Or the sensor.. When the gauge or sensor is bad and causing the needle to drop all the way down, the warning light (and ding) will turn on. Ive had this happen in my monte and my bonneville. Changing the gauge stepper motor in the monte fixed that problem. A hot needle thru the cluster lense (to hold the gauge needle in place) fixed that issue in the bonneville.. It got to the point where the chime wouldnt stop so theres that..
DannNL
Jul 23, 2019 05:52 PM
ktagrnma3
Aug 6, 2015 12:30 PM
mikemollic
Dec 27, 2013 01:41 PM
magnnuss_75
Jan 14, 2009 11:20 PM
96_z34
May 17, 2006 10:45 PM
