OEM Sparkplug?
Old Feb 11, 2014 | 06:01 PM
UWAdventurer's Avatar
Default OEM Sparkplug?
What is the OEM sparkplug for the 2002 3.8L NA? I have looked everywhere and can't find it. What is the gap also please?
What does everyone else like in their 2002?
Old Feb 11, 2014 | 06:25 PM
Use AC Delco replacements. Where did you search? There should be parts for them literally everywhere.
http://www.summitracing.com/parts/ac...el/monte-carlo
Old Feb 11, 2014 | 07:09 PM
JC Colon's Avatar
AC/Delo Iridium or NGK Plugs Gapped at 60 degrees!!!!! The word on the MCF Forum is Do Not Use Bosh! The don't work well in these cars!!!!!
Old Feb 11, 2014 | 08:50 PM
I couldn't find anything that actually said it was the OEM plug part number. That is what I was trying to find. Tons of other plugs available, thanks for the info.
Old Feb 11, 2014 | 09:17 PM
JC Colon's Avatar
Check the GM parts web site
Old Feb 12, 2014 | 05:05 AM
butch049's Avatar
AC Delco Iridium Part # 41-101 gap 60 good for 100000 miles get them at OReilys. I think $7.00 each.
Old Feb 12, 2014 | 05:42 AM
Iridiums were what came with these cars new.
On the 3400's (which the modern ones I believe also used iridiums), I have switched to NGK Platinum plugs (after shipping, I can normally get them for about $3 a plug from RockAuto). They have worked fantastic in all 3400 cars I've put them into. I have yet to put them into a 3800, but I would expect the same results.
FYI - AC Delco for a while now has been re-branding NGK plugs. I have a set of factory plugs I pulled out of a car in my garage that have branding from both NGK (engraved/stamped into the metal) and AC Delco (ink stamped on the ceramic).
Old Feb 12, 2014 | 07:38 AM
I'm a huge fan of using RockAuto to get the part numbers and such.
They always have a section where you can find in parenthesis what was OEM and they list the gap.
Old Feb 13, 2014 | 07:36 PM
Thanks everyone, the help is appreciated.
Floydcarlo
May 13, 2014 09:23 AM
Habbibie
Jun 27, 2013 01:09 PM
Dam20735
Apr 19, 2013 10:39 PM
Deadsnake
Aug 22, 2010 07:39 AM
Lee55
Jun 10, 2006 07:38 PM
