Need HELP-HELP-HELP! Can't get into my Monte!
Old Aug 28, 2014 | 01:23 AM
jaydflash's Avatar
Arrow Need HELP-HELP-HELP! Can't get into my Monte!
Okay so here is the deal. I have an 03 Monte Carlo SS. And the battery is dead. So I can't unlock the doors. And I have recently rebuilt the car and so when I put the key in the door, it turns fine, but nothing happens so I'm assuming that the little metal clip that goes from the lock mech to the rods came off. I can still get in my trunk, but I can't seem to find a way to drop the rear seats down from the trunk. Am I missing how to do it? And if that works is it possible to pop the hood from underneath the car?
Last edited by Space; Aug 28, 2014 at 05:19 AM. Reason: 2 get attention 4 new member
Old Aug 28, 2014 | 02:09 AM
Hi Jay,
Sorry 2 read about your problem Wish I had a easy answer, but the below is the best that I can do at present. I hope one of our tech member see's your thread & can give you a answer.
Good Luck
Check the below links to see `if you can get any infor that may help you
If my battery is dead and the doors and trunk are locked, how do I ...
forums.bimmerforums.com/.../showthread.php?...battery...dead...locked...
Dec 31, 2010 - 24 posts - ‎16 authors
If you're battery is dead and your doors are locked, first try this ... If you can gainentry into the cabin of the car...all that is required to jump start ...Dead Battery-Locked out-Alternative Emergency ...
Aug 14, 2011
E38 locked with a dead battery - How to get in ...
Jul 21, 2006
More results from forums.bimmerforums.com
► 2:52► 2:52
www.youtube.com/watch?v=POE_gwZrv-A
Aug 3, 2012 - Uploaded by Gary Zimmerman
HOW TO OPEN YOU CAR WHEN YOUR BATTERY IS DEADWHEY ... How to Open a Locked Car with the Big Easy CarUnlocking Tool by ...
No mechanical car door key. Battery dead as a doornail. How open ...
boards.straightdope.com › ... › MainGeneral Questions
Sep 2, 2013 - 50 posts - ‎18 authors
OK battery is dead as a doornail (left lights on or something). All doors are locked. How do you get in the car? Maybe there is some kind of chip ...
Help! I can't get into my car. I think battery is dead.? - Yahoo ...
https://answers.yahoo.com/question/index?qid...
Feb 24, 2013 - I suspect that my car has a dead battery because there are lights near my . ... to get to the battery in your car to use the remote to unlock the car.My car battery is dead and my key is locked in the ...
Sep 24, 2013
How to get into my car, battery dead, keyless remote ...
Sep 4, 2009
Car Problem - battery is dead, key & power lock remote ...
Jan 11, 2009
My car battery is dead and im locked out?
Feb 19, 2008
More results from answers.yahoo.com
how to open car when battery is dead - CarGurus
www.cargurus.com › QuestionsBMW7 Series
CarGurus
Jul 29, 2007 - how to open car when battery is dead - i cant open the car door. mybattery ... You assume all door have a mechanical lock, when in fact many ...
">dead battery. car won't unlock - Car Talk
community.cartalk.com/discussion/.../dead-battery-car-won-t-unlock
Jan 30, 2013 - Is the lock now seized up because of lack of use or will the key not go in because battery is dead? Will I be able to re charge this battery ...
Old Aug 28, 2014 | 05:48 AM
Question
https://montecarloforum.com/forum/ge...get-car-37462/
Click above past MCF link on this subject.
Good Luck
Old Aug 28, 2014 | 07:00 AM
gprtech's Avatar
The Starter motor is accessible right under the front of the car, and it has a direct connection to the battery. Connect a battery charger positive terminal to the starter lead, and the ground terminal to some accessible metal pint that's grounded ( the screws on the starter would work).
Charge your battery and open the car.
Old Aug 28, 2014 | 08:36 AM
03SSLE's Avatar
If you can get into the trunk use a flashlight and look at the top edge of the back seat. There is a spring loaded hook that holds the seat in place (top right as you look at the seat from the trunk). Pull it towards you to release the seat and push it down. Crawl through and unlock from the inside.
Old Aug 28, 2014 | 09:01 AM
Thanks George & Mike for helping a member in trouble Great information 4-Sure!
MCF = Member's Helping Member's
Old Aug 29, 2014 | 03:38 AM
jaydflash's Avatar
I can't seem to find that latch in the trunk. You said it was on the right side?
LennyLeonard
Nov 15, 2016 06:02 PM
Dstevens
Oct 7, 2012 04:29 AM
Budsjlm
RWD Tech Guides '70-'88
Dec 3, 2011 09:30 PM
Cloud_Master
Mar 24, 2008 11:13 PM
