My Monte
That's a good lookin' Monte. As far as cutting the springs go...not really a good idea. Your ride quality and handling will suffer. If you do decide to cut them I would only remove about 1/4 of a coil at a time until you achieve the desired ride height. If you cut 2 full coils initially you may end up with the inner fender wells sitting on the tires.
I would get the right springs to drop it further or look into coilovers. You will have a rougher ride on cut springs and the struts probably won't last as long.
