My monte
My monte
This is a thread I'm posting for the monte of the monte. I don't think I've ever done a post on here about what all my mods are. I'll try and get some pics in there too. I'll try and keep the mods organized by section:
Exterior
-BK1 full body kit
-Black ebay headlights
-Dominator cowl hood
-5% tint in back, 20% on the back sides, 35% on the sides
-GTS taillight blackouts
-Rear tail panel painted white to match the car
-Focal F5 18" chrome wheels
-BFG KDW2 tires 245/45/18 all around
-Streetglow pro series blue underbody neons
-Streetglow high/low beams (blueish color)
Interior
-7" tv fiberglassed in center console
-Window switches relocated to center console
-Push button start replaces cig lighter
-Blue LEDs illuminating the shift numbers
-Blue neons illuminating the HVAC and dash
-Chrome dash bezel
-Whiteface gauge overlays
-3 gauge A Pillar pod
(AEM UEGO wideband O2, 30/30 boost vac, oil pressure)
-Fiberglass rear deck housing 6.5"s and amp mount
-Fiberglass door panels w/ blue neon in bottoms, and blue LEDs in handles- each has a pair of 6.5"s
-Fiberglass inner trunk panel for mounting two 6.5"s and a blue mirror plexi bowtie in the center (still under construction)
Audio, misc
-Pioneer dehp730 deck-stolen
-Earthquake D3 sub amp-stolen
-Earthquake 2200.4 4 channel amp-stolen
-2 12" Atomic ELE subs in custom ported box-stolen
-8 Massive audio 6.5" coaxs (w external crossovers), 2 in each door, 2 in rear deck, 2 in trunk
-Audiocontrol line driver
-Tsunami high end RCA cables
-2/0 power, battery relocated to trunk (plan was to run a pair)
-DEI Sidewinder alarm/remote start w/ window roll down module
-Backup camera mounted under spare tire well
Suspension
-Z34 front and rear sway bars
-GM strut tower braces in the front and rear
-Blue painted front calipers
-Braided stainless brake lines all around
-R1 concept drilled/slotted rotors all around
-EBC red stuff brake pads all around
-HELD coilovers in rear
-BMR trailiing arms
-BMR lateral arms
-Black powdercoated center rear subframe
-Energy suspension rear sway bar bushings
Engine (sorry for the really random order)
-L67/4t65HD swap from 98 GTP
-Bottom end professionally balanced and race preped
-Diamond 9.5:1 pistons, coated
-ARP main studs
-ARP con rod bolts
-ARP head studs
-MLS head gaskets
-balance shaft delete
-Rollmaster double roller timing chain
-ATI balancer
-Meziere billet flexplate
-ZZP S4 ported heads
-HS 1.7:1 aluminum roller rockers
-ZZP 3/8 O/R pushrods
-Intense stage 3 blower camshaft
-ZZP ported lower intake manifold
-DPP headers
-Meziere electric water pump
-PRJ alternator relocation/AC delete
-TB heat shield
-Lokar flexible stainless dipstick
-WBS 3000 stall converter
-ZZP square poly mounts
-Intense round poly engine mounts
-Yella Terra intercooler/adaptor
-140AX Whipple supercharger (currently 4.0" pulley)
-PRJ plug wires
-PRJ fuel logs
-65# injectors
-Walbro 255 fuel pump
-Autolite 103 plugs
-180* drilled thermostat
-Shift kit
-Ported throttle body
-Lots of custom polishing, etc
Other
-Windshield washer fluid tank delete
-Polished stainless coolant overflow mounted in front of radiator under plastic
-Passenger side fuse box flipped and mounted into fender well; stock PCM box deleted
I think that pretty well sums up the bulk of the mods to the car- obviously much more is coming soon (the next step is a biggie ). Other than the bottom end work on the engine- I have done all of the work; all the paint work, all the fiberglassing, the rest of the engine build, all of the pcm tuning, etc etc Any questions, just feel free to ask.
From here, it is only going to get more extreme. Once I get a garage- the first order of business is to finish the paintwork on the side skirts and hood, and to do some shaving (gas door due to rust bubbles, probably will relocate behind a taillight; and both locks/handles- since the car got broken into and the drivers side lock is gone).
Then starts the big part of the plan- rear wheel drive coversion using a camaro/firebird underbody setup (similar to the John Moss monte but w/ a V6). I don't have anything ironed out yet- but the idea is to use a T56 or TR6060 6 speed manual, stronger rear end, minitubbed for a 305mm+ rear tire (I'd like to be able to hook halfway well in lower gears on the street), CTS-V front calipers with the Z06 14" rotors, a tubular K member (for reduced weight), and a manual PS rack (less weight, more road feel, and I'll be able to run the belt on just the crank, alt, and 1 tensioner pulley). I'd also like to run coilovers (the idea is to be able to get as low, if not lower than I am now in the rear, but at all 4 corners- or raise it up to a more driveable height.
For the engine, I'll put on my YT IC finally, ZZP aluminum heads (hopefully), DP nitrous from under the LIM (this was supposed to be part of the original build, but I ran out of time), YT snout and pullies, the YT RWD TB adaptor w/ 90mm TB and 100mm MAF, a PRJ custom cam (bigger than what I have now).
Then I'll move back to audio and figure out what I'm going to do with the pieces I have left after the theft. I don't really want a gutted racecar- I just want something that will be unique and fun to drive on the street with an occasional trip to the track. I guess only time will tell...
Anyways, for people that want pics of how she sits now (some older, some newer pics- you'll get the idea- most pics have dates)
Here are a bunch of various pictures of the car and its parts:
Exterior
-BK1 full body kit
Interior
-Chrome dash bezel
Audio, misc
Suspension
-BMR trailiing arms
-BMR lateral arms
-ARP main studs
-ARP con rod bolts
-ARP head studs
-MLS head gaskets
-ATI balancer
-DPP headers
-TB heat shield
-PRJ plug wires
-PRJ fuel logs
-65# injectors
-Autolite 103 plugs
-Shift kit
Other
