My 02 MCarlo window just dropped
Old Aug 25, 2009 | 10:20 PM
spiknek's Avatar
Question My 02 MCarlo window just dropped
Hey can anyone tell me or direct me to how to fix my 02 driver side window I was driving i heard a snap and my window came down how to fix and how to take apart?
Please assist.
THANK YOU ALL!!!!!!!!!!!!
Old Aug 25, 2009 | 10:40 PM
could be bad window button, see below posts from other members!!
08-19-2009, 01:31 AM
Pure2sin
Senior Member
I had a similar issue but my window wouldnt go up or down. I bought a switch from here:
http://www.gmpartsdirect.com/catalog/frameset.cfm
-Choose make and model and year.
-Choose "Door" then chose "interior trim" and to the right you will see window switch.
-Should be around $12 for the switch NEW.
Works fine now.
__________________
Old Aug 25, 2009 | 10:53 PM
spiknek's Avatar
well i dont think is the botton i'm almost sure is the regulator?
do anyone knows how to take the door panel apart so i can get to the regutalor
so i dont damage the door panel?
I can actually pull and push my window up and down by hand?
Old Aug 26, 2009 | 08:14 AM
Sounds like it may have just snapped off the track. But you won't know for sure until you open it up and take a look at everything.
Go around your door and find all the screws, unscrew them. I forget all the positions since I'm not looking at my door right now. Then carefully pry the bottom and sides out (they have small plastic clips holding them on be careful not to break them) and then the top part of the door is actually held on by metal hooks, so you just need to push/pull UP and the hooks will lift off.
Old Aug 26, 2009 | 08:26 AM
MAMONTE's Avatar
Please assist.
Sounds like a regulator to me....
Old Aug 26, 2009 | 01:11 PM
spiknek's Avatar
yeap the regulator cable is all messed up i try to fix it and put it back but when i try to test it it came all out againg i guess there ir no fix for that one just buy a new one
thye **** is like 120 dlrs they dont sell the regulator cable by it self?
Old Aug 26, 2009 | 01:24 PM
MAMONTE's Avatar
Yea, I figured...I think you have to buy the whole regulator...
Old Aug 26, 2009 | 02:27 PM
spiknek's Avatar
i know i just order it its gonna cost 109.99 plus tax
Old Aug 26, 2009 | 02:41 PM
whats the regulator cable made out of? you could try to make your own if its just a power cable type thing
Old Aug 26, 2009 | 03:42 PM
spiknek's Avatar
its the cable and due to that the piece the it rolls into also got ruin so the wire (cable) was going all over the place with in the casing!
Convaw
Jul 14, 2015 12:23 AM
Scooby doo
Sep 22, 2013 01:16 PM
cornerview
Jul 8, 2013 08:28 PM
85_SS
Jun 26, 2006 10:45 PM
00pacecar
Mar 30, 2006 11:54 AM
