Monte Carlo wont take any gas
Old Jul 31, 2011 | 05:15 PM
Flott's Avatar
Default Monte Carlo wont take any gas
I have a 2000 Monte Carlo and the gas hand was on a quarter of a tank. I drove further and the gas light came on so I pulled over and proceeded to pump gas in; however, the car let me put only $0.48 in and pushed the gas back out like it was full. What is going on?????
Old Jul 31, 2011 | 06:36 PM
mrl390's Avatar
Not sure what your problem could be, but making 4 threads on the subject doesnt get your question answered any faster.
Sounds like it could be an evap problem. The evap system vents vapors and pressure from your fuel system. Your evap system may have a clog in it somewhere. The charcoal canisters are known to go bad and send little pieces through the evap vacuum lines. Also, make sure your filler neck doesnt have something obstructing it.
Old Jul 31, 2011 | 07:57 PM
Flott's Avatar
Thanks just at my wits end. just have too many dependant upon this one car. I relieved the fuel pressure on the fuel pressure valve and released some pressure in the gas tank and that let gas go in but the car did it again not long after i got in a gallon or so.
Old Jul 31, 2011 | 10:16 PM
Mike 00LS's Avatar
That's what I was going to say too. You can try letting the pressure out but if the evap system is clogged up, it'll just build back up again until you clean it out so the pressure can't build.
Old Jul 31, 2011 | 10:34 PM
Enzo354's Avatar
STILL SLOW
Is the evap the only vent on the tank? Mine did that sometimes but if I let it sit a minute or two it would go in all the way. Try filling it slow so it can bleed of pressure.
Old Jul 31, 2011 | 10:42 PM
xxtheshockerxx's Avatar
RED DEVIL
my 2003 used to do that too...never found out why exactly tho
Old Jul 31, 2011 | 11:18 PM
Mr.Monte's Avatar
maybe the pump? does it happen if you lightly apply the pump?
Old Aug 1, 2011 | 06:12 AM
mrl390's Avatar
I think the evap system and the cap itself are the only vents the fuel tank has, but with the cap off, it should vent air to allow fuel to enter. Makes me wonder if either the filler is clogged or whatever vents the tank while you fill it is clogged.
schoentges16
Feb 27, 2021 06:43 AM
BrandonStebing
Jul 25, 2014 11:03 AM
RasCricket
Aug 31, 2013 08:19 PM
blonco
Mar 31, 2012 02:16 PM
nlange
Nov 8, 2009 09:44 PM
