Lower Intake Manifold Project Blog: RickCoMatic
Old Oct 29, 2009 | 01:10 AM
RickCoMatic's Avatar
Default Lower Intake Manifold Project Blog: RickCoMatic
Coolant loss continues despite recent upper hose clamp replacement by Dealer.
Early detection of Lower Intake Manifold leak suspected.
Stock L-I-M removal and replacement begins.
Ordering needed replacement parts.
2004 Chevy MonteCarlo LS V6 3400 w/ Air
-Fel-Pro Manifold Gasket Kit PN# MS98003T
OHV Engine; complete kit inc. Valve cover gskts. -- $90.99
-Manifold Bolts Fel-Pro PN# ES72226 -- $20.99
-Mobil-1 5W/30
-Thermostat:
Duralast 180 ℉ PN# 15898 -- $10.00
-Fuel Injector’s / Rails O-rings:
-FEL-PRO PN# ES71190
OHV Engine; Lower set; Injectors to cylinder head -- $3.75
-FEL-PRO PN# ES71192
OHV Engine; Upper set; Injectors to fuel rail -- $3.75
-Throttle Body Gasket FEL-PRO PN# 61053
OHV Engine; Throttle Body Gasket -- $1.05
-EGR Gasket FEL-PRO PN# 70804 -- $3.02
Am I missing anything?
If the Manifold is coming off and the Push-rods removed, ... should the Lifters get replaced or not?
Is there anything I should ask to have done to insure this repair job will not need to be repeated?
Comments on the 180 Stat appreciated.
Old Oct 29, 2009 | 07:54 PM
Oct 29 2009
Confirmed Part Numbers.
I went to AutoZone to confirm the Part Numbers and prices that I looked-up on the web.
Everything matched.
The Car is parked. I'm NOT going to risk any damage.
On Monday the Monte gets towed to a Reputable Shop that has discussed the problem and will submit the claim under the Extended Warranty Program.
Old Oct 30, 2009 | 08:17 AM
So it's being warrantied and you aren't doing it yourself??
Old Oct 31, 2009 | 07:18 PM
I'll know the score, Monday.
I can't do it without some help. My back is always in pain.
If the job can get done under the Warranty, ... I inquire about them letting me Video and get pictures.
Rick & Evelyn
Shandley
Feb 1, 2012 08:44 PM
jimbo7
Feb 6, 2011 02:06 AM
RickCoMatic
Nov 11, 2009 11:41 PM
montecarlomike81
Feb 22, 2008 08:28 PM
