Low Oil Level Light...
Old Jan 29, 2008 | 03:19 PM
sickofsoyo's Avatar
Default Low Oil Level Light...
Today I was thrown a low oil level light... Ok, shut off the car, looked under it in the driveway, nothing. Pull the dipstick, More than enough oil. So I go back into the car and start it again, low and behold, no code. Could this be somethin goin wrong? or just a random code being thrown...
Old Jan 29, 2008 | 03:30 PM
Default RE: Low Oil Level Light...
[align=center]Hi Scott,[/align][align=center][/align][align=center]I call it the Monte Carlo Ghost [/align][align=center][/align][align=center]I've had (2) Monte's 05LT & 06LT3,[/align][align=center]and I've had similar things happen onlyonce, &[/align][align=center]never happened again.. I would always PANIC : ) when [/align][align=center]it happened [&:][/align][align=center]I would do research the problem, but couldn't [/align][align=center]find anything.[/align][align=center]Yours could be the pick up unit that monitor's the oil,[/align][align=center]Orit was one of thoseMonte `Ghost just mess'in with U : )[/align][align=center][/align][align=center]I would suggest, be alert to any changes, & see `if[/align][align=center]it comes on again...If it does, I would check the electro[/align][align=center]sending contact that's monitors the oil level.[/align][align=center][/align][align=center]Maybe another Member has had this problem &[/align][align=center]a solution. If so, please respond. [/align][align=center]Good Luck Scott[/align][align=center][/align][align=center]LOL - LOL[/align]
Old Jan 29, 2008 | 03:35 PM
Cowboy6622's Avatar
were you parked on a real steep hill in either direction for any period of time? this could cause the oil in the pan to flow one way or another and thus trip the sensor when it thinks the oil is low.
Old Jan 29, 2008 | 08:28 PM
RocknSS04's Avatar
Check the connection on the sensor, in the side of the oil pan.
Old Jan 29, 2008 | 08:58 PM
sickofsoyo's Avatar
flat surface in park, and ok, Im on it, thanks guys.
sipster19
Jul 31, 2014 08:03 PM
frankboni
May 26, 2014 08:22 PM
TMoney
Aug 18, 2013 02:37 PM
Endo
Feb 3, 2009 09:07 PM
dogmanx
Jun 29, 2007 08:02 AM
