Info: Low Beams on with HIGHs
Old Jul 1, 2014 | 10:16 AM
04 NT1MD8R's Avatar
Default Low Beams on with HIGHs
My last car was a 97 Regal GS, I was a member of that forum as well. Some members had figured out how to keep low beams ON while the high beams were on. I am curious if anyone has tried this on our M/C? Since both cars are on the same platform, they may use the same harness. It was explained as something easy to do, just running a wire from the passenger side fuse box to the front box.
My drive into work is ALWAYS in the dark with critters crossing the road(darn 5am start time grr) and I'd like to be able to see better since I live out in the boondocks with little to no street lights. I run lows with fogs on but I need more distance with the up close lighting as well.
I'm an old guy and I remember having all 4 lights on when on High beam on my cars in the past. It was nice to wide and distance with what light were available then. Please let me know if anyone has tried this on their M/C.
Old Jul 1, 2014 | 10:45 AM
Here is a post from NAIOA.com of the mod.
Someone over at 2000MonteCarlo asked me about doing quad headlights, so I pointed him to the How-To on NewImpala, but he wanted a cleaner solution, so I came up with the following:
Quad Headlights
In order to keep the low beams on when the high beams are on (for normal headlight operation, not DRL), we need to "bypass" the dimmer switch on the stalk (when the headlights are on only)
On the harness that runs along the column, it comes to a 40 pins connector...you will need to tap into 1 wires here as well as tap into 2 wires at the BCM and find a ground (high current)...
You will also need a standard Bosch style automotive relay...
Relay Connections:
1) Pin 86: Battery +12V (Low current, drives the relay coil) BCM C1 - Pin A3 Orange
2) Pin 85: Headlight Signal Gnd (Low current, drives the relay coil) BCM C1 - Pin B3 Black/White
3) Pin 87: Column Connector Pin C4 (Brown on column side, Dk Blue on car harness side) (Use fairly heavy gauge wire (14 awg or better), this supplies current to the low beams)
4) Pin 30: Ground (Use fairly heavy gauge wire (14 awg or better), this supplies current to the low beams)
What this will do is, whenever the headlights are on (not DRL mode), the low beams will be energized, regardless of what position the dimmer switch is in...
If you want to add a switch to enable/disable this, interrupt pin 86 on the relay, it''s headlight relay signal...
Use at your own risk and your mileage may vary
BBEngineer
Old Jul 1, 2014 | 05:59 PM
monte07's Avatar
I don't know when they did this.
my 7th gen both stay on when the highs are on.
I am glad chibiblacksheep is able to help you more
svzpt71
May 11, 2015 06:30 PM
Hiroska
Apr 22, 2013 10:45 AM
Feb 22, 2012 02:07 PM
mickey
Mar 20, 2008 06:15 PM
04MonteLS
22
Aug 5, 2005 05:20 PM
