6th Gen ('00-'05): List of issues on my Salvaged '02
Old Feb 26, 2013 | 09:27 AM
Driving with your MAF unplugged for an extended period of time is a great way to run too rich and ruin your cat, if it's not already ruined
Old Feb 27, 2013 | 10:48 PM
TarShan's Avatar
Absolutely correct, I agree completely! I was only suggesting he try this as a diagnosis and temporary fix, not to be run long term. He wont appreciate the gas mileage for long at any rate, I know I didn't, and I only ran it as such for a week while I was waiting for the replacement MAF.
Old Mar 14, 2013 | 05:35 PM
Monroe's Avatar
Monte of the Month -- December 2013
Alright, so how long should i safetly drive without it? And do i just let it hang loose when driving?
Old Mar 14, 2013 | 05:50 PM
Monroe's Avatar
Ive also noticed when i shut the car off theres a small "sizzle" sound coming from the area of thr crossover of the headers. Is this normal?
Old Mar 14, 2013 | 06:06 PM
You could have a small leak where coolant passes through the TB
Old Mar 14, 2013 | 07:53 PM
Monroe's Avatar
You mean around the coolant elbows? I just had those replaced :/
And how long can you drive without the MAF plugged in?
Old Mar 15, 2013 | 05:49 AM
No, the throttle body. A small amount of coolant passes through that, and the TB mates with the UIM above the cross over.
You shouldn't drive around at all with the MAF unplugged. It's typically just a diagnostics thing, it's going to put your car into a mode where it runs rich.
Old Mar 15, 2013 | 07:43 AM
TarShan's Avatar
Depends on how long you need to be able to replace the MAF. Like Chibi said, runnin' without it can toast your cat(let alone your gas mileage), and these cars tend to do that with a natural proclivity as it is without any help. the wires, Meh. Just make sure they're not hanging close enough to a manifold or anything and you should be just fine. I pulled mine out of the socket just enough to leave it anchored, just not making contact.
Old Mar 15, 2013 | 11:03 AM
SSilver's Avatar
Sunroof problem = New sunroof Motor
Stalling = Bad MAF possible as stated.
Blown fuses/intermittent faults = Check for bare wires, loose connectors and system grounds.
Subwoofer rattle = Dynamat or similar products will help.
Shaky steering wheel = Wheels & tires may need to be balanced. If shaky only under braking, brake rotors may need to be turned or replaced.
Old Aug 11, 2013 | 11:57 AM
Metalsmith's Avatar
Mine started stalling and got worse till you had to start by blipping the throttle and feathering the gas to keep running, cat glowed red hot...we swapped out everything and asked a guy to use his Tech II scanner ... when we started it up , he said shut it off.... pulled all the wires and gas lines up from behind the TB.... there was a big melted hole where the flex tube from the egr, goes into the UIM.... egr was stuck open and the hot gas from the exhaust caused a melt down.... ECU threw every find of code there was as it could not cope. Glad it did not melt into the TB water passage, as I have heard that cause a lot of grief... He stuffed a wad of duct tape in the hole and 3 patches on top and it ran like new back to the shop...but would not think that would last for long.... I replaced EGR and UIM.... replaced LIM gaskets while it was down ... runs great !!!
