Junk Yard Run
Old Nov 29, 2015 | 11:25 AM
Shandley's Avatar
Default Junk Yard Run
I have a 2001 Monte Carlo SS (N/A).
I am headed to the junk yard in about half an hour.
Short of a top end swap, anything you can think of off hand as to what should I grab??
This is the kind of thing I am looking for....
"It's always good to have a spare _______"
"The stock _______ are garbage but the 2004 Grand Prix (or what have you) had good replacements"
"The throttle body on a 1998 Buick Lesabre is ported better and bolts on with a slight mod"
I am going to a broken engine mount bracket (my fault... loose bolts and hard driving = broken cast aluminum parts) but my wrecker is over 2 hours away so I don't go too often.
Any suggestions?
Old Nov 29, 2015 | 11:50 AM
turbo monte's Avatar
that mount you broke, if its the passenger side one get that mount from a supercharged 3800 (gtp, monte, etc) they are cast iron and will never break again. also bolts on with minimal issues. if you can get the icm and coil packs with it and it will make the swap much easier! (some people say the supercharged coil packs are slightly better then the na coil packs anyway)
Old Nov 30, 2015 | 09:25 AM
Shandley's Avatar
They did have a supercharger 3800 there but the bracket was taken. Well, I was able to grab a couple aluminum ones.
Man, it was tempting to grab the whole engine and just get to work but I didn't have the time.
Thanks for the post!
