Jacking up the monte
Old Jun 26, 2010 | 07:58 PM
04TurboSS's Avatar
Awaiting Email Confirmation
Default Jacking up the monte
So i just tried to jack up the monte and i cracked the spot that i normally put the jack. Where do you guys put it?
Old Jun 26, 2010 | 08:35 PM
04MonteLS's Avatar
For the front I put the jack either on one corner of the engine cradle or at the jack point just behind the front wheels. For the rear I just use the jack point just in front of the rear wheels.
Old Jun 26, 2010 | 08:48 PM
04TurboSS's Avatar
okay, is the jack point where its like the circle areas? I put it there and i heard a bunch of creeking.
Old Jun 26, 2010 | 09:01 PM
you can kind of see it by the rears, its like doubled metal area
Old Jun 26, 2010 | 09:53 PM
04TurboSS's Avatar
Thanks guys, I found it.
Old Jun 26, 2010 | 10:08 PM
There are other places you can use also, but first I gotta say, I always hear crunching and crackling kinda stuff when I do use the jack points. But you can also use the (A-arm is it called?) whatever the thing is that allows the front wheels to turn. And as for the rear, you can use the frame itself, I always do, that and a cinder block so I can get it up higher if I need to.
Old Jun 27, 2010 | 12:11 AM
What part did you crack then? lol
Old Dec 13, 2024 | 10:13 AM
Sassypants's Avatar
my 2005 monte carlo is barried in the mud. I'm not sure where to hook up a chain or strap to pull it out with my truck and it's starting to rain again. I'm very frustrated, please help!
Old Dec 13, 2024 | 03:20 PM
I'd hook it to the big square metal cradle under the engine + transmission. Very substantial, structural, and plenty of space to wrap a strap around.
And dig out around the tires as much as possible so it can actually roll out / youre not basically lifting it out.
Mels SS
Jan 6, 2014 07:01 PM
Mr. 960
Mar 12, 2007 11:52 PM
