INTAKE
Old Oct 18, 2007 | 09:44 PM
06MCLTZ's Avatar
Default INTAKE
I am going to add the CAI to my car. I was planning on retubing the intake to get ride of the stock intake tube. Everything looks pretty easy but the only problem is I believe it's the crankcase vent/breather in the intake tube. What can I do to make it work?
Old Oct 18, 2007 | 09:53 PM
06MCLTZ's Avatar
Default RE: INTAKE
Could I just drill a hole in the tube and put a grommet there and stick it in or what?
Old Oct 18, 2007 | 09:57 PM
06MCLTZ's Avatar
Default RE: INTAKE
Plan on using this the 3" ID and 6" long to go from throttle body to MAF, I measured and the stock tube is 5" so I can just cut it down
Old Oct 19, 2007 | 11:48 AM
06MonteSS's Avatar
Default RE: INTAKE
you've already gotten my reply on ls1tech, but I'll post it here for those that do not venture over there and are interested...
you'll want to make sure you put on the new intake tube before drilling anything, so you make sure you put the hole in the right spot...
then, take out the base part of that assembly from the current intake hose - that hard plastic tube piece that the hose clicks on to... that piece will pull/pry out...
get a 3/8" ID grommet...
drill a 1/2" hole in the tube...
put the 3/8" ID grommet in that hole...
put that little hard plastic vent tube piece into the grommet...
reinstall the new intake tube...
click the vent tube back on...
done.
also, might wanna measure your MAF ends and the throttle body... I thought mine was 3" too, until I went to install a new intake hose... come to find out it's 3 1/4" - and my 3" intake hose I had didn't fit.... so I'm still stuck with using the stock intake bellows...
can't find a 45 degree, 3.25" intake hose anywhere...
EDIT: found silicone intake hoses in 45*, 3.25"... but they're friggin' $50+...
Old Oct 20, 2007 | 10:52 AM
RocknSS04's Avatar
Default RE: INTAKE
$50 is still WAYcheaper than a K&N cold air intake, by BUNCHES of $$$
Wayne
http://www.cardomain.com/ride/2319272
Old Oct 20, 2007 | 04:35 PM
God_Bot's Avatar
Default RE: INTAKE
It would be interesting if you could do a bit of a writeup, as I am interested in doing the same thing but I don't really have any idea as to how to start...
Old Oct 22, 2007 | 05:01 PM
04 Intimidator's Avatar
Default RE: INTAKE
Gonna have to build it and take some pics for the other 06+ guys.
seanpeezy
Jan 10, 2016 04:05 PM
augi
FWD Tech Guides '95-'07
Mar 25, 2012 12:17 PM
big green dog
14
May 30, 2005 06:42 PM
04MonteLS
May 29, 2005 12:35 AM
montejass
May 26, 2005 04:04 AM
