I am thinking about getting a 2005 SS
Old Jul 11, 2016 | 04:13 PM
LoudMC's Avatar
Default I am thinking about getting a 2005 SS
First let me thank you all for the knowledge that you share. I have found a lot of very useful information here and I am hoping that you all could help me out one more time. I am thinking about getting a 2005 supercharged SS. I was wondering if the supercharged 3800 still had the intake manifold gasket issue or if that was resolved, and how do the transmissions hold up? I have never had a supercharger before, is there anything I should lookout for? Is there anything else that I should be aware of before I buy? The car looks like it was taken care of in the past. Thank you again for your time and knowledge.
Old Jul 11, 2016 | 06:32 PM
I have a2005 Monte carlo Supercharged SS
I have no problem with it 98,000 miles.
It did had a new engine at 16,900 miles.
Old Jul 11, 2016 | 08:39 PM
turbo monte's Avatar
Engines are very strong but I believe still had the lower intake gasket issue. Trans is hit and miss depending how it was driven but generally above 80k miles I feel your doing good.
Other than that the normal stuff, rockers rusted out, rear struts towers rusted out, etc.
Old Jul 11, 2016 | 10:43 PM
The supercharger is not a big deal for reliability. It is designed to last a long time with no maintenance. About the only common issue is the plastic coupler going bad inside the snout but it's a cheap and easy fix. It also has its own oil supply that you should change (but it is very infrequent, nothing like engine oil).
My biggest concern with supercharged cars is modding history. Look at the SC pulley and bolt to see if it looks like it has been removed before. I wouldn't touch an l67 that has been modded without further investigation first.
