How trans fluid i
Old Jan 24, 2013 | 08:50 PM
Dam20735's Avatar
Default How trans fluid i
I need to refill my trans back with fluid how much do I put in it 02 monte carlo
Old Jan 24, 2013 | 09:56 PM
From my experience if you just did a filter and fluid from the pan you will need to add about 7 or 8 quarts of new fluid. But then I have only did this once and about 5 months back, but I believe thats about what I put back into it. You can always take back any extra and get a refund.
Old Jan 25, 2013 | 09:21 AM
MAMONTE's Avatar
If you do a pan drop and filter change, you need to buy 8 quarts. Put 7 in to start, and drive it till it's warmed up. Check the fluid level (while car is running and it's fully warmed up). Chances are, you will need to add about another .5 quarts, for a total of 7.5. That's about where I fall every time, and I've changed my fluid at least half a dozen times.
Also, I would recommend buying the newer Dexron VI fluid.
Old Jan 25, 2013 | 09:37 AM
Mike I believe thats the now recommended trans fluid for our Montes.
Thanks for posting it! (7.5 is the correct fill amount)
Old Jan 25, 2013 | 09:52 AM
MAMONTE's Avatar
You're right, its the only fluid recommended for all GM cars that used Dex III. However, you can still buy unlicensed versions of Dex III (which I'm sure are fine, but I would not recommend them just because they aren't licensed).
Zmonte34
Mar 10, 2013 11:20 PM
deezdrama
Jun 7, 2012 08:01 AM
04IntimidatorSS
May 31, 2012 08:10 PM
echolmberg
Oct 22, 2008 12:17 PM
rchurch
Mar 17, 2008 04:25 PM
