How much for the intake manifold gasket repair?
Old Aug 23, 2017 | 10:26 AM
johnt671's Avatar
Unhappy How much for the intake manifold gasket repair?
As posted in the title, what might it cost to have this done? Ballpark figures are fine.
The sad part is I was thinking of selling this car because we don't drive it much, but it would be a hard (and cheap ) sale like it is now.
Thanks.
Old Aug 23, 2017 | 02:28 PM
user 35764368's Avatar
If you do the work.....pretty cheap...about 100$ while yer at it may as well change out the valve cover gaskets,,,,,,,and if ya need to...be a great time to get at them rear spark plugs. I would think a good shop could do it in about 2 hours, I'm gonna guess at about 3-400 dollar job. but ive heard of folks payin 6-800. You can allways call around and ask.
Old Aug 23, 2017 | 04:32 PM
johnt671's Avatar
Thanks, I will call around and check, but I wanted to get an idea of the cost so no one could say"such a deal I have for you at a thousand bucks. Thanks for the info.
Old Aug 24, 2017 | 10:38 AM
Aerocoupe86's Avatar
Monte Of The Month -- November 2016
sharp is pretty spot on, its not that big a job. its no 30 min job either but even at that 3-400 clams would get it done here parts and labor. Just request they use the better grade of intake gaskets. fel-pro offers a better grade and not much more expensive.
Anyone trys to quote a grand..............run
Old Aug 24, 2017 | 06:20 PM
shawn parker's Avatar
I paid 1000 but it was because they spent too much time tearing down the donor motor before realizing it wouldn't work with out "a lot of Jerry rigging"
I told them to forget the SC and just do the intake job
Old Aug 24, 2017 | 11:05 PM
Which one are you needing replaced the upper or lower? Lower one I can see them going for the big $$$ to replace it.
Old Aug 26, 2017 | 01:32 PM
turbo monte's Avatar
A lower intake manifold job shouldn't be more than $600
Old Sep 19, 2017 | 08:09 AM
johnt671's Avatar
Thanks for the replies. I got it to the shop last week so they could look at it. The more I thought about it, the less I thought it was a big problem. There was no coolant in the oil or trans fluid, the radiator was just gunky. I had them flush the cooling system ank told them to get rid of the Dex-cool, but they put Dex back in it. On the way home the low coolant light came on again so I need to replace the sensor. Since I have to drain some of the coolant out to change it, I'll also give it a good flush and go with the green stuff.
