- How many `miles on your Monte Carlo + Problems ?
Old 11-27-2013, 08:40 PM
Originally Posted by Barovelli
Loose Lucy passed the 150,000 mile mark tonight somewhere along US 101, probably Prunedale.
No breakdowns or fixes needed since the thermostat last winter.
Hi Barovelli & thanks for your updates. It's great to read that your Monte is treating you good...Happy Thanksgiving to you & family + all our Monte Carlo Family
  #292
Old 11-27-2013, 09:50 PM
ohara's Avatar
Carloss has 267, 893 kms a few issues but they were all relatively minor in the grand scheme of things, a MAF sensor, EGR Valve and Driver side power window switch. there was another problem when I first purchased where it would start and then just die but once under acceleration it was fine but for the life of me I can't remember what the name of the part was that was the cause of the problem. Oh yeah also the annoying ABS wheel speed sensors, but I have since learned to live with the abs light on the dash
Monique has 132, 000 kms, *knock on wood* has only had regular maintenance on her, just replaced the exhaust from the cat back and tires and windshield wipers.
  #293
Old 12-01-2013, 10:33 AM
owens91's Avatar
Just an update. Jack has 101800 still has highbeam out issue, poor gas milage but tht could been due to a bad tire.
  #294
Old 12-11-2013, 12:00 PM
84 CL 229 (3.8) with close to 135 miles on it. Only thing that I can say is a problem would be minor electrical problems due to thieves and my ac compressor went out. I recently had to replace radiator (original radiator replaced). Other than that the V6 is running like a champ. Currently working on getting body lined up properly and ready for paint and swapping that 229 for a 383.
  #295
Old 12-21-2013, 05:45 PM
My 85 SS has 104,000 miles and I had a new tranny and driveshaft installed 9 years ago. I had issues with the torque converter when the car was less then a year old. Turns out my drive shaft had a defect that did not show up until it cracked the rear of transmission housing due to some kind of failure. No issues since then.
No motor work has been done outside of tune ups, oil, and a lightweight radiator replaced a semi clogged and rock damaged original. Replaced the fan clutch when it seized and did not allow the fan to move freely.
Took out the air conditioning compressor for weight after freon was no longer available.
Modern shocks make the car handle so much better, especially if you use some aftermarket wheels and tires.
I like the car because it is easy to work on and not much computer control compared to modern cars.
Oh yeah, original paint is in ok condition, but car needs a repaint, but that will all happen someday when I restore and modernize it where possible.
Going on 30 years and hopefully 30 more! lol
  #296
Old 04-05-2014, 06:56 AM
2006 LT 3500, 123,000 miles. So so car. Changed water pump about 65k. Shift lock solenoid wire broke twice. Changed both left a right heat blend door acctuators. Left and right front hubs. Alternator. Tie rods. Just change struts all around. Oil filter adapter gasket.
  #297
Old 04-05-2014, 09:25 AM
nycmonte, have you had a transmission problems?
  #298
Old 05-07-2014, 01:48 PM
2001 SS
3.8L
238,000 plus miles
Problems:
Feb 2012 -EGR Valve causing check engine light to display- Dealer reprogrammed PCM
Feb 2013 axle damaged leaked tranny fluid
Nov 2013- Transmission rebuilt
Feb 2014 - very rough idle, vacuum leak, tuneup and new vacuum hoses
May 2014- rough idle, stall - replaced IAC valve, worked for 1 day, still troubleshooting.
Getting frustrated!!!
  #299
Old 05-19-2014, 08:12 PM
2004 SS
around 109,000 with used engine. Now the oil pan gasket is leaking again....
  #300
Old 05-19-2014, 09:34 PM
xxtheshockerxx's Avatar
RED DEVIL
Mine is at almost 52k now
Quick Reply: - How many `miles on your Monte Carlo + Problems ?
