- How many `miles on your Monte Carlo + Problems ?
#145
2005 LS
Bought used w/17,186 in Feb. 2006
Have the 3.4L V6
I do minor work on her, major things are done by a good friend of mine (who is a auto mechanic)
Current mileage: 60,276 Miles
The only issues I've had and fixed: Aside from a sway bar bushing, water pump, Radiator cap, Instrument Cluster (Burnt out bulbs, sticky Speedo), A/C Cluster (Burnt out bulbs) Driver Power window switch (top portion broke off), Passenger Door Lock switch (had short and was causing the doors to lock and unlock at random), brakes and tires (maintenance items) and new rims , my car has been "Like a Rock" As you can tell, most of my problems were electrical..
Have the 3.4L V6
#148
i have an 84 monte with a 383 stroker about 20k on drivetrain motor trans rear body...200k probably lol heres my list
sway bar end links
holley 600
tune up
oil changes
4 starters
collector gaskets
mufflers (blew a hole thru a cherry bomb turbo) have thrush glasspacks now
now the list of problems...
huge short kills starters and batterys if u leave them hooked up for more than an hour or so and now crept to my dvd player
power steering pump seal went out
oil pan gasket is leaking everywhere
trans pan leaks
long tube headers make my exhaust low
but in the end im getting a painless wiring kit and a new starter and am going to get it back up to code me and my monte have a love hate relationship
sway bar end links
holley 600
tune up
oil changes
4 starters
collector gaskets
trans pan leaks
