How to Change front brake pads???
Old Jun 7, 2018 | 05:52 AM
Carrie Alexander's Avatar
Question
Originally Posted by EarnhardtZ71
I just replaced the pads on all 4 corners of my car. I bought the OEM ceramic pads from the Chevy dealership. They were $60/set so it was only $120. I use OEM stuff as much as possible.
I swapped all pads and replaced both rear rotors in about an hour and a half, using the same method as donutboy.
Hi,
So yall say that its easy to change the brakes on monte carlos.... i have a 2006 Monte Carlo 6cyl 3.9L How easy would it be to change the front brakes myself? I've changed brakes before but Im so not looking forward to how much its gonna cost if i take it to a shop and have them change it. I know its gonna be an arm and a leg and at this point in time in my life i cant afford neither an arm or a leg to get them changed. Ive also looked on youtube for videos on how to change them but i cant find any for my year make an model. Only thing i seen was for bake brakes, nothing for front brakes.
Old Jun 7, 2018 | 06:36 AM
Jeffs02rwdSS's Avatar
If you have seen videos on how to change brakes , just transfer that information to your Monte Carlo. Most cars use the same design set up on calipers. If you're unsure you can get a bookbag the parts store about $15 or go to the library and check out a Haynes manual for your car..It has all the information your looking for to fix your car.
Old Jun 7, 2018 | 07:47 AM
Smile This one will help
This one will help it has the front disc brakes on a 2005 Monte and yours should be the same.
Shandley
FWD Tech Guides '95-'07
30
Jan 1, 2018 07:59 AM
JaxJim
Oct 18, 2016 02:58 PM
Red Nightmare
Nov 23, 2013 10:04 PM
GqAmbitions
Mar 31, 2012 06:29 AM
orthokneepa
Jul 26, 2011 12:46 PM
