HELPPPPP knock or flex plate
Old Mar 13, 2013 | 04:35 PM
Dam20735's Avatar
Default HELPPPPP knock or flex plate
Can anybody tell me what they think this sound might be???
Old Mar 13, 2013 | 06:16 PM
Jeez, where do you think it's coming from. Could that be a heat shield on the exhaust
Old Mar 13, 2013 | 06:49 PM
Dam20735's Avatar
It sound like a piston but I'm not sure an this will be the 3rd motor
Old Mar 13, 2013 | 07:33 PM
Red Nightmare's Avatar
oh my god what a rattle.
Old Mar 13, 2013 | 07:43 PM
are all the plug wires on in the correct order? That sounds nasty......
Old Mar 14, 2013 | 06:13 AM
aussiek2000's Avatar
Quit running it like that or you will be buying an engine for sure.
Start my manually rotating the engine with a breaker bar. Listen to see if you hear grinding inside the bellhousing.
Old Mar 14, 2013 | 08:44 AM
Question
It sounds to me like the flex plate hitting the inspection cover...maybe a bolt is coming out of the torque converter hitting it also! Pull the inspection cover off.. Look inside..i think you'll be surprised by what you find...Sounds like the flex plate is cracked!!!
What were you doing when it started making that sound?
Probably something that should not be done...
Neutral slam?
Reverse drive wholeshot?
Getaway spin?
Stuck? Power reverse,drive (rocking)Does it grind at start up?(like grinding rocks?)
Old Mar 14, 2013 | 09:44 AM
turbo monte's Avatar
That don't sound like a bearing. Turn the engine over by hand ans see if you can find the issue that way. Is it in time this time? Being out of time can cause a lot of parts to smash each other. I would check compression as well.
Old Mar 14, 2013 | 09:45 AM
That's how mine sounded when I shattered my con rod
bama_z34
Nov 1, 2010 10:59 PM
gopack47
Aug 11, 2010 09:46 PM
RocknSS04
34
Jul 16, 2010 11:38 PM
Smokester
Dec 16, 2008 08:30 PM
RocknSS04
Jan 13, 2008 06:17 PM
