help
Old Feb 19, 2007 | 06:15 PM
manny's Avatar
Default help
i dont know if this goes here
anyway im not driving the monte carlo right now its been parked for a couple of months now.......but every 2 weeks i start the car and let it run for about 10 minutes
today i went to turn the car on and let the heat warm on inside and the fans are not working??????anyone know if this would freeze because its been realy cold here
thanks for any help
Old Feb 19, 2007 | 06:31 PM
Default RE: help
Hi Manny,
Did you check your fuses ? My friend had a similar problem
and it was a blown fuse.
Oh, I hope you treated your gas with additives to prevent it
from jell'in up : (
I'm not a tech, and I hope another member post their thoughts.
Good Luck Manny,
`Space
Old Feb 19, 2007 | 06:51 PM
manny's Avatar
Default RE: help
ya i got good gas in it and take care of that thanks
im still new to the monte carlos
i looked at the fuse box by the drivers door can you help me out with what fuse it is ....i have a 2002 ss
would that be where the fuse is?
Old Feb 19, 2007 | 08:35 PM
Default RE: help
ORIGINAL: manny
Hi Manny,
[&:]Get out your Owner's Manuel & Go to the index
& look for Fuses
[&:](It will show location & should show a fuse chart &
what fuses are for what operation.)
If you don't have your book, you can go to a place like Auto Zone
& they will check it for you. `Free : )
I hope that other members with more knowledge will response to your post
for additonal information. Manny, be patience....we have
many members with a lot of tech knowledge & I'm sure they will assist.
Good Luck
`Space
Old Feb 19, 2007 | 08:58 PM
InTheIROC's Avatar
Default RE: help
It doesn't work on any speed? It's not likely that it would freeze unless some water got into there.
Old Feb 19, 2007 | 09:20 PM
manny's Avatar
Default RE: help
ORIGINAL: InTheIROC
no its not working at any speed
it was working fine the last time i turned the car on
maybe water did get in there somehow
the weather is gonna warm up in the next couple days ill check again
thanks for the help guys
Old Feb 19, 2007 | 10:16 PM
RocknSS04's Avatar
Default RE: help
My '01 had 2 speeds go out. It had a multi-resistor block go bad way up under the dash. I replaced it with an epoxy encased block. I blamed it on my stereo.
My '04 is not the same style. It is a reostat control instead.
This doesn't sound like that to me, but for reference, that was a pain in the *** to replace.
http://www.cardomain.com/ride/2319272
Old Feb 19, 2007 | 11:20 PM
InTheIROC's Avatar
Default RE: help
ORIGINAL: manny
ORIGINAL: InTheIROC
I looked at the wiring diagram for the blower motor circuit, and it looks as if the blower motor resistor can fail in a certain spot to cause the blower to not work on any speed. I would still check the fuse to start... if water got in and froze the motor and you tried to turn it on, it could have caused an increase in amperage to blow the fuse. If the fuse is good, get a test light (or a DVOM if you have one) and make sure you have power going to the motor.
Old Feb 20, 2007 | 10:14 AM
wiz kidd's Avatar
Default RE: help
blower motor resistors are very common this time of year, we sell a ton of those...and especially on gm's
thats what it sounds like to me anyway...
Old Feb 20, 2007 | 01:58 PM
manny's Avatar
Default RE: help
ok guys thank you again for the help
i got a good friend that owns a shop down the street from me/
i toke the monte there to get my windowns tinted today and hes gonna look at that problem with the heater fan .
he said it could be frozen water must have got in it and froze it
i can wait to see the monte now with dark wondows it will look nice im sure and thne the new rims on it
I LOVE MY CAR LOL
