help
i dont know if this goes here
anyway im not driving the monte carlo right now its been parked for a couple of months now.......but every 2 weeks i start the car and let it run for about 10 minutes today i went to turn the car on and let the heat warm on inside and the fans are not working??????anyone know if this would freeze because its been realy cold here thanks for any help |
RE: help
Hi Manny, Did you check your fuses ? My friend had a similar problem and it was a blown fuse. Oh, I hope you treated your gas with additives to prevent it from jell'in up : ( I'm not a tech, and I hope another member post their thoughts. Good Luck Manny, `Space |
RE: help
ya i got good gas in it and take care of that thanks im still new to the monte carlos i looked at the fuse box by the drivers door can you help me out with what fuse it is ....i have a 2002 ss would that be where the fuse is? |
RE: help
ORIGINAL: manny ya i got good gas in it and take care of that thanks im still new to the monte carlos i looked at the fuse box by the drivers door can you help me out with what fuse it is ....i have a 2002 ss would that be where the fuse is? Hi Manny, [&:]Get out your Owner's Manuel & Go to the index & look for Fuses [&:](It will show location & should show a fuse chart & what fuses are for what operation.) :) If you don't have your book, you can go to a place like Auto Zone & they will check it for you. `Free : ) I hope that other members with more knowledge will response to your post for additonal information. Manny, be patience....we have many members with a lot of tech knowledge & I'm sure they will assist. Good Luck `Space |
RE: help
It doesn't work on any speed? It's not likely that it would freeze unless some water got into there.
RE: help
ORIGINAL: InTheIROC It doesn't work on any speed? It's not likely that it would freeze unless some water got into there. no its not working at any speed it was working fine the last time i turned the car on maybe water did get in there somehow the weather is gonna warm up in the next couple days ill check again thanks for the help guys |
RE: help
My '01 had 2 speeds go out. It had a multi-resistor block go bad way up under the dash. I replaced it with an epoxy encased block. I blamed it on my stereo.
My '04 is not the same style. It is a reostat control instead. This doesn't sound like that to me, but for reference, that was a pain in the ass to replace. http://www.cardomain.com/ride/2319272 |
RE: help
ORIGINAL: manny ORIGINAL: InTheIROC It doesn't work on any speed? It's not likely that it would freeze unless some water got into there. no its not working at any speed it was working fine the last time i turned the car on maybe water did get in there somehow the weather is gonna warm up in the next couple days ill check again thanks for the help guys |
RE: help
blower motor resistors are very common this time of year, we sell a ton of those...and especially on gm's
thats what it sounds like to me anyway... |
RE: help
ok guys thank you again for the help i got a good friend that owns a shop down the street from me/ i toke the monte there to get my windowns tinted today and hes gonna look at that problem with the heater fan . he said it could be frozen water must have got in it and froze it i can wait to see the monte now with dark wondows it will look nice im sure and thne the new rims on it I LOVE MY CAR LOL |
