Header Panel 83 & 79/88 question...
Old Oct 26, 2011 | 10:24 PM
gr3g4554's Avatar
Default Header Panel 83 & 79/88 question...
I was wondering will a 79 header panel bolt up to the 83s. If not what about the 88s with the one headlight component?? Trying to get away from 83 ls look.
Old Oct 30, 2011 | 04:08 PM
Zeke's Avatar
You are likely going to have a problem buying something "off-the-shelf" that will mouth right up to that without mods on the passenger side.
I have a 1982 El Camino, same underhood everything, with a 400 small block, & had to hammer the underside of one tube to make it clear the suspension. These cars/trucks are very hard to put headers on, unless you get a custom set built.
I used Hedman headers. They have been on since 1993.
Old Oct 31, 2011 | 12:31 PM
rj's Avatar
rj
The '86-88 LS Montes, the front fenders are not the same as the SC and SS Montes. The LS front fenders are actually 1 inch longer at the wheel well. So if you decide to use the '86-88 piece on your non-LS Monte you'll need to swap front fenders.
A guy on Monte Millennium Generations wanted his LS to be an SS. For the parts to fit and look right he had to buy a complete SS nose and swap it out. I remeber him telling me if you try to use the LS nose on non-LS fenders some of the bolt holes don't line up.
Old Nov 4, 2011 | 07:03 PM
gr3g4554's Avatar
Thanx rj I'll probably will just find a 83 header panel around, because I was going to change the looks due to mine being all messed up. But I'll keep da look
thesheiladivine
Apr 24, 2012 04:49 PM
CruizinKev
Apr 1, 2010 04:27 PM
Richie F
May 4, 2009 06:37 PM
3800monte
Mar 30, 2008 05:49 PM
87monte
Jan 26, 2007 10:18 AM
