got rear ended today... fog light is out
Old Mar 23, 2011 | 08:17 PM
hollf1's Avatar
Default got rear ended today... fog light is out
So I'm driving home from work and the traffic in front of me stops so I do the same but the woman in front of me doesn't stop in time and hits me. We both pull into a parking lot and I look at my car. There really was no damage on the back on except for some small scrape by the rear license plate. I took her info and let her go without calling the cops. I get home and find out my right back rear fog light doesn't work after the accident. How much trouble would it be to fix that. I'm thinking maybe the bulb is just bad after the accident since the light wasn't cracked at all. What do you guys think?
Old Mar 23, 2011 | 08:41 PM
Mike 00LS's Avatar
Well those are technically reverse lights, not fog lights... my guess is she could have shaken a wire loose when she hit you, if you say the bulb isn't even broken it's a good chance she didn't actually "break" anything. Hopefully.
Old Mar 23, 2011 | 08:45 PM
I'd try new bulb see if that fix's it ...
Old Mar 23, 2011 | 09:04 PM
werewolf-odst's Avatar
i ran into the back of a truck and it bent the whole trunk and bumber, but the reverse light still work, and the lens ic craked in half, so it may just be the bulb, and all you may have to do is unscrew it and change it. =]
Old Mar 23, 2011 | 09:14 PM
mrl390's Avatar
Just the force of the accident was probably enough to burn out the bulb. Happens all the time. I would check a little closer for damage as well. Take the bumper cover off and inspect the beam and the sheet metal behind it. Plastic bumper covers can take a hit and bounce right back. High strength steel on the other hand doesnt fare so well.
brendan127
Aug 5, 2012 02:45 PM
lougreen03
Apr 28, 2012 04:59 PM
1FasImp
Jan 6, 2012 01:46 PM
76MonteMan
Oct 9, 2010 06:16 AM
03SSandlovinit
Dec 4, 2005 10:20 AM
