6th Gen ('00-'05): fuel gauge
Old Dec 24, 2013 | 12:04 AM
Default fuel gauge
I have a 2004 monte carlo ss that the fuel gauge is not reading right. It seems that when I first start the car it will read right but when I drive it for a bit then stop, it will start to move a lot up and down until I start to drive again then it seems like it is reading correct again until I stop again then it will do the same thing again.
Old Dec 24, 2013 | 09:26 AM
turbo monte's Avatar
My first guess would be the fuel level sending unit it wore out. It has little metal contacts the rub to give fuel reading and eventually they wear off and can't get a good reading anymore. The fuel level sending unit is on the actual sending unit and pump in the tank and there is an access door in the trunk just behind rear seat under the carpet.
Old Dec 25, 2013 | 10:00 AM
Montelicious's Avatar
Mine just started doing the same thing. It is also causing the wrong reading on the heads up.
Old Dec 26, 2013 | 01:28 PM
Monte_Man04's Avatar
The other problem you may have (and it is very common) is that you gauge motor has gone bad. This problem happened in almost every GM vehicle from the early to later-mid 2000's. In my 2004 Monte Carlo SS, my fuel gauge, speedometer, tachometer, and oil level gauges are all bad and give wild readings. They still sometimes come back to normal, but always go out again. I have the newer, less problematic replacement motors, but I haven't had the chance to take apart the dash and install them.
Old Mar 13, 2014 | 10:14 PM
mtbadger's Avatar
Default Gauge problems
I have an 02 Monte that reads full all the time. I also have an 00 GMC Sierra that none of the gauges work. I was told it is a faulty ground to the instrument cluster.
mchugh2001
Jan 28, 2015 11:50 AM
S.O.G.
Nov 26, 2014 09:10 PM
robknight13607
Mar 20, 2013 09:14 AM
01 Monte SS
14
Jan 21, 2013 11:57 AM
04chevyboy
Jan 29, 2012 09:50 PM
