Opinion Needed: Fuel/engine management for turbo's
Old Feb 4, 2014 | 07:14 PM
Shelbo Mustang's Avatar
Default Fuel/engine management for turbo's
I am going to turbo my 2000 SS and need ya'lls help on what to do with the Fuel/engine management.
Old Feb 4, 2014 | 10:22 PM
turbo monte's Avatar
A basic turbo kit with no engine work on pump fuel all you need is 42# injectors.
If you decide you want to run e85 or build the engine to make more power and raise the boost then 60-90#injectors are needed along with a upgraded fuel pump and pump rewire. (I'm using a racetronics pump with there rewire on 60# injectors and pump fuel and so far havnt maxed out the injectors but we shall see soon.
Old Feb 4, 2014 | 10:57 PM
Default Cool
Thanks,I did'nt think it would be that easy.About how much boost do you think I could put to it?One more thing were were are you all getting all your upgrades?I'v been all over this computer and there's not alot out there!
Old Feb 5, 2014 | 12:04 AM
dbaldwin's Avatar
Zzperformace, cartuning, stattama, 3800 pro, there's a huge aftermarket. I also have a basic turbo build planned and john (turbo monte) has given me some great advice. He will also tell you you're going to need a new, built, trans.
Old Feb 5, 2014 | 08:16 AM
Boost depends on what supporting mods you have (cam, heads, fuel, intercooled, etc)
There is a huge aftermarket world as dbaldwin said. Also on other forums there is a huge used part market you could save a ton of money by using used parts.
Dbaldwin knows me to well lol yes you will need a built trans for sure as well.
Old Feb 5, 2014 | 09:59 AM
dbaldwin's Avatar
You can get 42# injectors off of an l67 right?
Old Feb 5, 2014 | 11:00 AM
Hiroska's Avatar
Crazy how its more parts for the 3800, than the 5.3 lol.
Old Feb 5, 2014 | 11:03 AM
L67 only run 32# I believe
Old Feb 5, 2014 | 09:39 PM
Not sure what size l67 injectors are but I know they are smaller than 42# for a fact.
dillonjbenjamin
Feb 4, 2014 12:23 AM
vm1971
Apr 17, 2009 10:53 AM
BeachBumMike
Jul 25, 2007 09:05 AM
wiz kidd
Nov 29, 2006 07:41 PM
BeachBumMike
Oct 25, 2006 05:26 PM
