exhaust resonator
Old Jul 20, 2016 | 05:22 AM
Rick Riley's Avatar
Default exhaust resonator
hey guys , thinking about removing my resonator for little more sound to go along with the two chamber mufflers i installed , any thoughts on this , good idea /bad idea? i am sure some of you have already done this lol ,thanks ric
Old Jul 20, 2016 | 05:40 AM
rexdews's Avatar
Resonator delete will just create more noise in the cabin and nothing else.
Old Jul 20, 2016 | 05:56 AM
Rick Riley's Avatar
oh ic , so no advantage out the back, better kept it then , thanks
Old Jul 20, 2016 | 03:50 PM
Sidestreet's Avatar
I'm not some exhaust pro, but it seems to me that resonators are basically "assistant mufflers" that specialize in reducing droning noise. Also, their straight-thru design doesn't hurt exhaust flow, as long as there's no pipe constriction inside the resonator. So there's more good reasons to keep a resonator than not to!
Old Jul 20, 2016 | 06:14 PM
turbo monte's Avatar
Above are all correct. The 3800 can get very raspy very quick and deleting the resonator is the easiest way to achieve rasp. What some people do though is change the resonator to a glass pack muffler. I would suggest buying a downpipe with either a high flow cat or if you can get away with no emissions etc then go catless downpipe. Just keep in mind if going catless you will throw a o2 sensor code and engine light unless you have that code tuned out.
Old Jul 21, 2016 | 08:20 AM
Rick Riley's Avatar
hiya turbo ,i have the 5.3 motor in my monte not the 3800 , but your suggestion would probably be the same either motor ?
Old Jul 22, 2016 | 09:17 AM
wasnt sure exactly what you had, your car info under your name there says 2001 monte but the pic is different lol
not sure about the 5.3, hopefully someone with that engine can chime in for you.
Old Jul 22, 2016 | 09:39 AM
Rick Riley's Avatar
i know lol, it has the pic on my 2006 ss that i have now but the info for my 2001 that i had before ,i have tried to change it with no luck , you have any ideas on how to change it ?
Old Jul 22, 2016 | 12:38 PM
i believe it goes off the first vehicle listed in your garage. not sure though
Old Jul 22, 2016 | 12:48 PM
Rick Riley's Avatar
cool beans turbo that fixed it !!
