6th Gen ('00-'05): Erratic rpm while in park
Old May 5, 2016 | 02:01 PM
Nicknogivashiz's Avatar
Default Erratic rpm while in park
2001 Monte Carlo 3.8 V6 217000 miles. Check engine light on with the following codes; P0102 MAF sensor low frequency. P0332 knock sensor malfunction (bank 2).EVAP solenoid No.1 control circuit malfunction.
The evap solenoid electric wires were cut, so I spliced them together, and it has stopped the hesitation on acceleration and the erratic rpms while in drive. But now when in park the rpms rev erratically. What more can I do? It's starting to feel like a losing battle with this POS. Please help, and thank you.
Old May 5, 2016 | 02:41 PM
Check the wiring to the MAF first. If the wiring checks out, clean the MAF sensor with MAF sensor cleaner.
If that doesn't do it, you might need a new one.
