Electrical issue headlights, bcm????
Old Feb 4, 2013 | 01:49 PM
NYGiantsfan's Avatar
Exclamation Electrical issue headlights, bcm????
HEY GUYS SO I HAVENT HAD HEADLIGHTS TURN ON IN A MONTH AND DONT HAVE MONEY TO GET IT CHECKED OUT AGAIN, THE LAST TIME I TOOK IT TO A SHOP THEY MADE ME SPEND MONEY ON NONSENSE
SO AS HE WAS CHECKING IT OUT HE NOTICED AND TOLD ME I HAVE A POSITIVE LEAD ON ON BOTH WIRES FROM THE LOW BEAMS. NO NEGATIVE LEAD.
MY FOGS R OK, HIGH BEAMS R OK BUT CANT KEEP ON EM ON UNLESS I KEEP THE TURN SIGNAL STICK PULLED BACK
HIS RECOMMENDATION WAS THAT I NEED A BODY CONTROL MODULE.
I NO WHERE IT IS AND FOUND A FEW JUNK YARDS THAT HAVE EM FOR LIKE 50$ BUT ID HATE TO SPEND THAT IF ITS NOT IT
ANY THOUGHTS?
THANKS AGAIN
Old Feb 4, 2013 | 01:50 PM
tps221's Avatar
Check your fuses
Old Feb 7, 2013 | 10:26 AM
That was the first things I checked fuses bulbs ballasts even put regular halogen bulbs to test the connection the thing that I don't understand is why the + and - wires to the bulb are showing + on both wires I have no ground
Old Feb 7, 2013 | 10:56 AM
03SSLE's Avatar
Originally Posted by NYGiantsfan
...HIGH BEAMS R OK BUT CANT KEEP ON EM ON UNLESS I KEEP THE TURN SIGNAL STICK PULLED BACK...
If the lever doesn't *click* and keep the high beams on when you activate them that's a sign the switch is worn out and needs to be replaced. It's possible the switch isn't completely returning to the low beam position and that's why they don't work. If you know how to read schematics you could trace the wiring from the switch and jump (bypass) the connection for the low beam circuit and see if they worked then. If they did it would verify the switch is faulty.
...even put regular halogen bulbs to test the connection...
If you are running aftermarket lights (i.e. HID) there could be a problem elsewhere in the circuit, but I would still have the multi-function switch checked and replaced as needed.
Old Apr 15, 2013 | 09:44 PM
just seen the reply i need to set up my notification manager, thanks, believe it or not i still haven't got it checked out school got me broke lol i managed to not use it these past months during the evening but now its getting annoying. im gonna try and see if i can find the schematics via torrent n hopefully be able to trace it if not ill just take it to another shop.
if it is the bcm im gonna try to avoid that $500 job and rewire the lights my self and install a diff switch
Old Apr 18, 2013 | 04:59 PM
by multifunction switch are you talking about the **** that turns on the ights and interior light?
AlSpaulding
May 15, 2015 08:02 AM
Henderson21
Jul 26, 2014 03:37 PM
Ssouthwick7
Dec 20, 2012 10:02 PM
DE02Carlo
Jun 2, 2012 09:28 PM
intimidator701
Jun 20, 2011 05:30 PM
