Are ebrakes different from the rear brakes?
Old Mar 19, 2013 | 03:12 PM
iMSeRiOuS's Avatar
Default Are ebrakes different from the rear brakes?
I had my oil changed and on the sheet it says that "e-rear brakes almost metal to metal"
Are these different from the pads? I can't take a good look, someone borrowed my jack.
Old Mar 19, 2013 | 03:25 PM
TheMonteMan's Avatar
the emergency brake is inside the rotor on the rear. its not the same pad that rides on the rotor thats visible throw the wheel. its like a drum brake almost. its shaped like a horse shoe. you cant see it from outside. at least thats the case on my 06.
Old Mar 19, 2013 | 04:44 PM
aussiek2000's Avatar
They likely lied to you. It is a mini-drum brake setup inside the rotor. There is no inspection plug to check the parking brake. 2nd, it doesn't wear unless you drive around with the parking brake on. 3rd, do you even use it?
Old Mar 19, 2013 | 05:14 PM
iMSeRiOuS's Avatar
OMG...
read the report wrong.. the "E-" was from something on the top line.
Well at least I know the difference now
Old Mar 19, 2013 | 06:38 PM
FWIW, you can pull the rear wheels and get a good look at the brakes. I would replace anything under 2mm of material left. If they were "metal on metal" you would hear it.
3800monte
Feb 20, 2008 06:17 PM
3800monte
Feb 11, 2008 11:58 PM
mike01ss
Jul 18, 2007 08:25 AM
IntimidatorSS
Sep 26, 2005 03:09 PM
04MonteLS
Jun 12, 2005 08:25 PM
