DRL on a 2002 Monte Carlo???
Old Jun 19, 2013 | 05:17 PM
owens91's Avatar
Originally Posted by Sellncars
Exactly. Now because of this i need another relay and still have the same problem. Ive been a Gm fan since ive been old enough to drive, but shoving this garbage to us is BS... All the bulbs are good, the light is on because of bad advise... So people if you want the drl disabled, dont just jump and do what others do, do your homework first.
yea i had bought a back up relay and changed it and stil highbeam out and both high and low beams was on, so i did the "cut the 87 pin" still got the same out come, my next step is to try and look at the connections, i wonder did he mean the connections to the harness or to the bulb tho
Old Jun 19, 2013 | 05:19 PM
owens91's Avatar
Originally Posted by JC Colon`
What is the condition of your harness, plug and wires? I Had a similar problem when I bought my car. Thought that one of my Hi beam bulbs was bad. Bought a new set and when I went to change them I noticed there was a lot of oxidation on the pins in the plug. So I changed the bulbs and cleaned the plugs for both my Hi and low beams. I haven't had any problems Since. That was just over a yr ago. If the pins look dark or black, they a burned. If they look light green. They have been wet and have oxidized. Both will cause poor current flow and the warning light to come on. I used a Very small flat head jewellers screwdriver to scrape them clean.
where exactly are the pins that you cleaned im not sure which ones you meant
Old Jun 19, 2013 | 06:48 PM
I'd like mine disabled as much as the next guy, but I haven't seen a method that works for sure problem free for 00-04. And no one seems to have any idea either
Old Jun 19, 2013 | 07:00 PM
owens91's Avatar
if i were to take the highbeam bulbs out would this make a service vehicle soon light come on?
Old Jun 19, 2013 | 07:04 PM
Probably throw the high beam out message and then your regular headlights would come on
Old Jun 19, 2013 | 07:12 PM
owens91's Avatar
right now i got the highbeam out message but yet my highbeams are bright and my regular headlights are on...at the same time
Old Jun 19, 2013 | 07:48 PM
Mike 00LS's Avatar
Because your computer is thinking the high beam is out it will trip the low beams on. Occasionally when I try to use my signal and I pull it back and hit the "flash to pass" the left side light doesn't come on right away, on comes the "light out" warning and all 4 lights come on.
Old Jun 19, 2013 | 08:55 PM
Sellncars's Avatar
I'm back to square one, lights gone on the dash with a new relay. Did BBEngineering leave here? I hear that his harness works without any issues.
Old Jun 19, 2013 | 09:16 PM
JC Colon's Avatar
Check the pins on the harness at the connection to the bulbs. If the last owner put HIDs in without the complete kit. The extra heat would melt the plastic. If the connector wasn't seated to the bulb correctly then water would get in and cause the pins inside the harness to oxidize. It would be the same color as the Statue of Liberty. Either way, if that is the problem, putting new bulbs in will not solve it. Also, finding something to circuit in each pin to clean it is hard. I used a Very small jewelers flat head, a lot of scraping and lot of patience. Be careful if you find it to have been burned. The plastic of the harness will be brittle. Hope this helps.
Old Aug 6, 2016 | 11:19 AM
Robert John Salvatore's Avatar
Default Hood pin location
Hey guys just joined this i have a 2000 monte carlo ss and im wondering where a good location to put hood pins would be since the front of the hood is curved
