View Poll Results: A poll
I change my own & use Synthetic
36.36%
I change my own & use a synthetic blend
9.09%
I change my own & use conventional motor oil
27.27%
I have it done & use Synthetic
11.36%
I have it done & use Synthetic blend
0%
I have it done & use conventional motor oil
15.91%
Voters: 44. You may not vote on this poll
- Do you change your own oil/filter ? -
Old Apr 26, 2007 | 03:17 PM
  #41
GrandPaDave's Avatar
Default RE: - Do you change your own oil/filter ? -
My buddie's 1950 6-window straight-6 had a funky oil filter.
Old Apr 26, 2007 | 03:23 PM
  #42
rj's Avatar
rj
My '57 235 6 cylinder had the add on filter cannister.
Old Apr 27, 2007 | 01:15 PM
  #43
[align=center]Many of my Friends, Don't know how to change their oil/filter : ([/align][align=center]Below is a basic site that has information on How to change it, plus[/align][align=center]explore other subjects that are contained on the page.[/align][align=center][:-]Click the below link to read [:-][/align][align=center]http://www.associatedcontent.com/art...ngine_oil.html[/align][align=center][/align][align=center][/align][align=center]Hope it may help someone, Members, if you have a link or infor on this subject, please post it.[/align][align=center]We live & hopefully will learn to keep our Monte's in Top Condition.[/align]
Old Apr 27, 2007 | 04:03 PM
  #44
canadianmonte's Avatar
My engine rebuilder says to use Mobil 1 . He also says to use ACDelco filters because the drain back valve is better than most. I wonder who makes them ,or if GM Manufactures them.
Old Apr 27, 2007 | 07:13 PM
  #45
wiz kidd's Avatar
wix makes gm filters
you could always try a change to royal purple if your in my area i can sell you royal purple real cheap, but mobil 1 is also on sale right now @ canadian tire for a 4 litre jug and a 1 litre bottle packaged together...
so next time if your looking for something other than a gm filter try a wix 51040 filter
Old Apr 28, 2007 | 03:47 AM
  #46
Mrrench's Avatar
Wiz
I dont believe that you are correct on Wix making gm delco filters........
Old Apr 28, 2007 | 12:26 PM
  #47
wiz kidd's Avatar
i went in to the wix warehouse up here, its about 20-30 min away from where i live and they have about 1/4 of the warehouse is acdelco filters...now whether this just means they make them or they just stock them i'm not sure...but i was always told they made them...it could possibly be different in the states too...i'm not sure though..just always what i was told
Old Apr 28, 2007 | 01:09 PM
  #48
[align=center]
ORIGINAL: Mrrench
Wiz
[/align][align=center]Hi Michael, Why don't you think `Mod Wiz is correct ?[/align][align=center]I've attempted to search for the answer, but have not found it yet.[/align][align=center]Do you already have that infor ?...If so, please post...Thanks[/align]
[hr]
[align=center][/align][align=center]Major brands of oil filters available in the U.S. include Fram (an Allied Signal brand), (Wix, AC Delco), a General Motors brand) and Motorcraft (a Ford Motor Company brand). Some brands, such as Ford's Motorcraft, are manufactured by other companies (i.e. Purolator for Motorcraft) but are generally designed and quality tested by the brand selling them. Many of the brands manufature filters for a wide variety of makes and models of vehicles. For instance, Motorcraft sells oil filters that fit GM, Chrysler, Honda, and Toyota vehicles, in addition to Fords. The manufacturer usually provides a list of what makes and models they supply filters for.[/align][align=center]Some have argued that there is a major difference in quality of various oil filter brands, and some studies have proven it. Generally speaking, those branded by automotive manufactuers (such as Motorcraft and AC Delco as listed above) usually meet higher standards without costing significantly more than cheaper-made (and poorer performing) brands such as Fram or Penzoil brand. Very expensive brands such as Mobil and K&N perform excellently, but cost a lot more than traditional brands.[/align][align=center]Many major autoparts stores (such as AutoZone, which sells the Valucraft brand and NAPA, which sells NAPA and NAPA GOLD) offer their own brands of oil filters, but these are usually also made by one of the other major oil fiter makers.[/align][align=center]Oil filters are not limited to automotive use. Power generating stations use upwards of 40,000 gallons of turbine lube oil to lubricate large bearings. Hydraulic lines are used in industry for many purposes. All of this oil needs to be filtered and the level of filtration is much more stringent than that of standard automobile filtration. In these applications many times a resin impregnated glass fiber filtration media down to even 1um is used, whereas in automobile filtration it is always cellulose which has a micron rating of 50um or more. Industrial applications do not "change their oil" frequently as changing tens of thousands of gallons of oil @ $10 a gallon quickly adds up. This is why much higher quality filters are usually used. Subsequently the cost for an industrial grade oil filter can be anywhere from $50 to $1000 (depending on size). You can not purchase an industrial grade filter and expect it to fit on your car, as these filters are sometimes 6" in diameter and upwards of 60" long. Nor would you want to, as in automobile filtration problems often result from the additives package breaking down, more so than particle contamination. Major players in industrial oil filtration are Pall, Donaldson, Parker, Kaydon, and Vickers. The industrial oil filtration market is full of retrofitted or will-fit filter elements. Every major manufacturer has a filter element that will fit in another manufacturers housing. Some manufacturers specialize in only retro-fitting other manufacturers filters elements, usually [/align][align=center]for 1/4 to 1/2 the cost.[/align][align=center][/align]
[hr]
[align=center][:-]
Old Apr 28, 2007 | 06:32 PM
  #49
Mrrench's Avatar
Champion Labs filter
Old Apr 28, 2007 | 08:26 PM
  #50
ORIGINAL: Mrrench
Thanks `Michael, I'm sure learning a lot doing research about
Monte's & Cars. Thanks for posting....
`d-Space
