6th Gen ('00-'05): Dealerships stealing Engine Covers for recall!!???
Hello everyone. So I own a silver 2004 Monte Carlo SS Supercharged Limited Edition in pristine condition. I brought it in to a local dealership to get a recall taken care of that I've been putting off. The Oil leakage issue (which hasn't been a problem for me but I figured it would be a good idea to be proactive). The dealership stated that they were going to replace the forward piston cover and seal (also something with the keys so they don't turn off while in operation). So yesterday when I went to pick up my car I discovered that they had taken the plastic engine cover (in brand new condition) away. When I asked them for it back they stated that it's "property of GM" and that they were taking it as a precaution against engine fire. As I understand from reading the recall order, that issue was supposed to be taken care of by replacing the Piston valve cover and seal. No mention was made of taking the engine cosmetic cover away. The dealership refused to give it back and when I called GM about it they also said that they can't give it back. I suggested that they replace the function of that part of my car by doing something with the look of the supercharger casing, such as replacing it with a shined up cover or polishing the current one, perhaps...something to replace the function of what they took off. They refused to do anything. I suggested that they then compensate me for the part since it was my property, they refused. Is it just me, or is this wrong and potentially illegal? I understand that they're trying to minimize their liability in case of engine fire... But when recall work is done, isn't there a reasonable expectation that they would somehow replace the function of what they take away?? Never in a million years would I have taken my car in with the cover on it if I thought they would steal that from me. Anyone else have this issue, or any lawyers out there have any input?
Yes they will take it and not return it, and there's really nothing you can do about it short of just buying another one online or catching one in a junkyard if you so desire.
That might irritate me too since I love keeping my car original. On the other hand some people think the engine looks cooler without the cover. Even if you took the car to a show I doubt anyone would ask where the cover is, or even know that it ever had one.
My understanding was only that the cover wouldn't fit correctly if the recall repair was done. I had no idea they were stealing the things and I agree that sounds wrong to me.
I never take my car for recalls and instead opt to keep it in it original defective state. I still haven't changed a light bulb yet on my '04
I havnt bothered with the recall... I did replace my valve cover gaskets tho... and I removed the plastic plug wire thingy. as far as the engine cover goes.. I don't use that either... IMO it just retains heat over the fuel lines and upper intake, keep your ignition key separate from your other keys and youre good ta go there as well
. the only downside I can see is that an open recall will show on a car fax or history report,
As many said, that cover is part of the recall. It will fit just fine, but it is being removed because people who are sloppy and spill oil everywhere, that cover allows it to drip on the exhaust.
I agree, it is sad they do not allow you to retain it for car shows or garage art (such as signing a waver that states it will not be used while operating the car).
I am also interested in GM's terms. The recall calls this a "beauty cover", but the shop manual calls it an "injector shield". If it's a shield, it has a function. Granted, I have been running without a cover long before the recall.
Also, this complaint has been mentioned numerous times on this and other online sites. Best thing to do, is remove it before taking it for the recall.
If you're really that concerned about having one, just grab one from a junkyard or pick up one if the hundreds off of ebay. Just keep in mind if for some freak reason your car does burn to the ground, you'll then have zero legal recourse against GM.
