6th Gen ('00-'05): coolant leak
Old Dec 21, 2015 | 07:55 AM
indybleck's Avatar
Yup got one last week
Old Dec 21, 2015 | 10:58 PM
KCFITZ78's Avatar
I found this post on the forum. Hope this helps.................
I'm surprised with as common as this job is, we don't have a good how to guide in the tech info section
The job is easy, especially on a 3800. I've done it a few times. A lot of the stuff I feel is pretty straight forward. There are a lot of videos on YouTube about this, here's one I found that looked "start to finish". Just take your time.
LINK---> GM 3.8 Intake Manifold replacement. Removal the fast way WITH NOTES - YouTube
Recommendations:
- Get the Fel Pro metal core LIM gasket kit and doesn't matter much on the UIM gasket kit (I believe I've used a Dorman most of the time).
- Get the torque specs for the lower and upper intake (especially the upper, it's plastic, over-torquing means damage).
- I pulled the UIM off with the T-body attached. This is handy to inspect the UIM! The UIM failure is where the EGR "stove pipe" is (the pipe is literally a piece of pipe sticking up on the UIM, I believe Dorman gives a narrow pipe replacement to ward off UIM damage). On two sides of the UIM are coolant ports, they take coolant in and out of the T-body. Place a finger over one port, blow compressed air in the other, watch around the opening for the stove pipe for coolant or air to blow throw. If so, the UIM has gotten brittle and damaged (common UIM failure that causes coolant to enter the cylinders). Frame 11:07 the guy points the EGR opening on the UIM.
- If the UIM is damaged, you have two options. One is replace the UIM. The other (and cheaper), tap the coolant ports on the LIM, plug them. I used stainless steel set scres, I've soon others use brass plumbing plugs (I think the brass plugs are better, NTP threwads are finer then the ones on my stainless plugs). For extra insurance, JB weld the coolant ports shut on the UIM.
- As mentioned, change the T-body gasket (should come with the UIM gasket kit in most cases).
- Even though the guy does the job without pulling the tensioner assembly and the alt, I recommend doing it and change the coolant elbows while you are at it (Dorman now makes aluminum elbows, gets rid of another plastic failure point).
- Clean as much as you can. The cleaner things are, better the job is AND in some cases, improves car performance.
I think that's about it. I hope it helps!
Old Dec 23, 2015 | 05:06 AM
fatfig's Avatar
look at your oil cap, its probably mixing in with the oil....it happen to me. had to replace all the gaskets....costly job if you take it to a shop. i watch a video on youtube a few times. and i did it myself and save 1k.
Old Jan 24, 2016 | 11:03 PM
xpage's Avatar
I just noticed my engine coolant is very low, been losing oil for awhile now. Since i replaced the elbows, and have a thick dogsh*t like clump on my rad cap, I am guessing I have a LIM leak. not looking forward to replacing it, engines are the one thing that does scare me to mess with, though 1k is 1k.
What kit is preferred to fix this issue
1- FEL-PRO MS98014T {#MIS16203A} PermaDryPlus®; Intake Manifold Gasket Set
2- ACDELCO 89017816 GM Original Equipment
Old Jan 25, 2016 | 05:21 AM
fatfig's Avatar
FYI, here is the kit your looking for ND THE PRICE IS CHEAP//////
Intake Manifold Gasket Set ACDELCO 89017816 GM | eBay
Old Jan 25, 2016 | 09:48 AM
plumbob's Avatar
IMO, the Fel-Pro gasket set is better. It has the aluminum reinforced core that resists meltdown. To my knowledge the ACDelco ones are still all plastic and eventually end up with the same problem as the original. Here's the Fel-Pro: Engine Intake Manifold Gasket Set FEL Pro MS 98014 T | eBay
I would also replace the Upper intake Manifold at the same time. here's the Dorman kit: http://www.ebay.com/itm/DORMAN-615-1...ZRpQbt&vxp=mtr
Old Jan 27, 2016 | 03:45 AM
xpage's Avatar
thanks guys. I picked up the Felpro and will also do the UIM too and valve covers since I am in the area and my front valve cover is leaking oil a bit
