>Chevy’s 460HP V8 Monte Carlo RWD<
Old May 26, 2016 | 09:42 AM
Arrow >Chevy’s 460HP V8 Monte Carlo RWD<
Exclusive: Chevy’s 460HP V8 Monte Carlo
Written by Jeff Smith on February 1, 1996 <>Posted b-4 on the MCF. Posted again for you !
There may be a rear-wheel-drive monte carlo on the way
View All 11 Photos
Mad Dr. Moss is at it again. Like the storied Dr. Frankenstein, Jon Moss has created another monster. But unlike in the novel, this factory hot rod is no experiment gone bad. While HOT ROD has featured mad-man Moss’ engineering creations in the past, this Monte Carlo is a bit different. There’s a real chance a version of this car could end up as an honest production piece, following a similar path as the Impala SS that first saw the light of day at the SEMA show a few years ago. Moss calls this car “the Monte Carlo Pro Street.”
When talk turns to performance cars, all rodders make a basic assumption: Real performance cars spin the rear tires, while only pretenders fool around at the front. This is a point that’s not up for debate. It’s accepted fact. Front-wheel drivers have never been able to compete with rear-wheel drivers (RWD). While the new Monte Carlo has made a serious impact on NASCAR Winston Cup racing in its inaugural year, the Monte’s street statement falls seriously short of carrying the Bow-Tie banner, with little more chutzpa than a front-drive V6. Until now.
Moss and his band of “imagineers” decided to inject some “correct-wheel-drive” testosterone into the Monte to pump up its muscle. But it’s more than just another flight-of-fancy concept car. The rumor is that while the green car struts its stuff, there is another RWD V8 Monte skulking outside GM corporate offices that has the potential to be a true production car.
Obviously, we at HOT ROD feel this is a car whose time has come. We believe so strongly in a RWD V8 Monte that we have included a reader ballot with this story to allow you to make your voice heard concerning this car. If you think this Monte should be built, take the time to fill out the ballot and send it to us. We’ll tabulate and publish the results in a future issue, and we’ll make sure that Chevrolet knows about it. Do it as soon as you finish reading this story.
The construction of the Monte Carlo Pro Street was no simple bolt-it-in-and-go operation. Moss and his band began with a production ’95 Monte and immediately ripped the entire floorpan out of the car, replacing it with a ’95 Camaro F-car floorpan. This required lengthening the Monte’s wheelbase by 3 inches, while also spreading the Monte’s ribcage by adding 4 inches to the track width. This modification necessitated bulged front and rear fenders that give the Monte a menacing look.
The F-car floorpan also tucks the engine under the cowl for better weight distribution while utilizing ’95 F-car upper and lower control arms, production rack-and-pinion steering and modified spindles mounting Wilwood calipers and Corvette 13-inch rotors. The front F-car framerails were adapted to the Monte’s front fascia and radiator support, while a special 3x3x.083-inch frame section was constructed utilizing F-car suspension pickup points for the rear suspension. A single-hoop rollbar was also fabricated to reinforce the chassis and the B-pillar area.
With a solid foundation, the real fun began with the buildup of a killer engine and drivetrain to give this Monte the brawn to back up its new image. This Monte demands a stout motor, but a big-block was too heavy to consider, so an all-aluminum 406-inch small-block got the nod while simultaneously improving the Monte’s weight distribution. The block is a Chevy Motorsports aluminum 4.125-inch-bore block reworked to accept the factory F-car LT1 engine mounts. A Callies 4340 forged-steel crank with a 3.75-inch stroke swings a set of Crower 5.7-inch Sportsman Stroker rods and Wiseco forged pistons. Speed-Pro 1/16-inch rings and Federal-Mogul bearings carry the load, and a Moroso oil pump and pan are responsible for doing the lubrication thing.
Erson supplied a hydraulic-roller cam with 302/310-degree advertised duration and .550-inch lift that actuates 1.6 Crane roller rockers and Smith Brothers pushrods.
A Cloyes timing set keeps the cam synchronized with a set of TFS Twisted Wedge aluminum heads. The heads were blended and port-matched to a reworked LT1 intake that incorporates a rear-mounted MSD distributor and crossover water passages. An Arizona Speed & Marine
58mm throttle body controls the air that’s mixed with Bosch/DFI fuel injectors, all controlled by a factory LT1 ECM. The assembled engine was then dyno tested, and it generated an impressive 466 horsepower at 6000 rpm and cranked out 458 lbs-ft of torque at a streetable 3500 rpm.
Since the Monte was obviously intended to be leaned on, Moss specified a special Borg-Warner T56 six-speed gearbox with a 2.97 First gear ratio that mates to a custom McLeod aluminum flywheel and a McLeod dual-disc Street Twin clutch-and-pressure-plate assembly enclosed in a modified F-car bellhousing. The rearend had to be able to handle all that torque as well, so the sturdy Dana 44 rear axle was beefed up with a 3.54 gear, a Torque-Lok differential and a pair of Strange Engineering street axles.
The front 13.4-inch disc brakes were matched with F-car 11.4-inch rear discs, and then a set of 17x9.5-inch front and massive 17x13-inch rear Boyds billet wheels were bolted on. A set of P275/40ZR17 front and P335/35ZR17 rear Goodyears help plant all that power while still moving smartly around those twisty-turnies.
Even with the substantial modifications made to the floorpan, the interior is not dramatically different. Moss added a ’93 Camaro center console to house the T56 shifter, retained the Monte steering column and had to modify the heater/AC housings to fit between the firewall and the dash. Other than some subtle modifications to the seats, the Monte’s interior is very close to production.
The Pro Street Monte was so new that Moss needed more time to fine-tune his creation before he felt comfortable allowing us to test it. In fact, he wasn’t even sure how much it weighed, so estimates of its performance potential will have to wait for more accurate data and some time behind the wheel. Certainly, this car has 12-second quarter-mile potential as well as road-burner handling capabilities, given its monster tires and F-car suspension. As soon as Moss gives us the green light for testing, we’ll let you know how much muscle this monster really has.
After you’ve finished reading this story, put the magazine down and turn your ear toward Detroit. Listen as intently as you can. What you may hear are the first tentative heartbeats of a new performance car struggling to survive.
MORE PHOTOS FROM THIS ARTICLEVIEW SLIDESHOW
PrevNext
1 - 9 OF 10
Old May 26, 2016 | 09:50 AM
Thumbs up >Bonus Chevy<>Do U Like it ?<>I do<
A 1955 Chevrolet Bel Air Built the Right Way
Written by Rob Fortier on May 26, 2016Contributors: Robert McGaffinFamily Bel Air-Loom: Jason Grimes’ 1955 Chevy finally gets built the right way
View All 25 Photos
What do you get when you combine two family generations, nearly four decades, and a 60-year-old car? Among other things, clearly priceless memories and—ultimately—one priceless ’55 Bel Air.
Alabamian Jason Grimes had the distinct pleasure of growing up in an automotive-fueled family atmosphere. As a kid, like many of us in our so-called midlife years, he built plastic scale models as his father wrenched on vehicles, both as a profession and a hobby. “My dad always had a shop and he was always working on or modifying cars and trucks … he taught me a lot,” Jason recalled. But that influence extended beyond his immediate family, as well.
2/25
“I can remember riding in the [Bel Air] with my uncle when I was a kid. Back then, it had a four-speed Muncie in it. He would let me shift the gears for him when he took me out from time to time. He used to drive the car back and forth to work for years, but then he ended up with a new car so he decided to paint the ’55 and put it away. The car sat for 13 years before he finally sold it to me for $2,000 … that was a lot of money back then (1990). Since that time I have owned the ’55 for 25 years—20 of that it sat in my dad’s garage. I could have easily sold it at least 50 times but I always held on to it with big hopes of building it to the car it is today.”
So, above and beyond that brief personal synopsis of the Bel Air’s family history, just exactly how did the Grimes’ ’55 come to be the “car it is today”? Well, along with the help of his ultra-influential father, Jason also enlisted the ultra-talented Brad Cline and his shop, Thunder Valley Customs, in White, Georgia, to bring the ’55 to where it’s at today.
3/25
It all starts with one of Art Morrison’s signature GT55 chassis—AME’s “CAD-engineered replacement chassis that gives the handling characteristics of an exotic sports car.” That’s all made possible by Morrison’s proprietary IFS, Strange Engineering fully adjustable coilovers, Detroit Speed power rack (versus a traditional “gear” box), beefy triangulated four-link (locating a TruTrac’d 9-inch rear), tunable sway bars front and rear, and 13-inch Wilwood binders tucked behind 20-inch Billet Specialties Stilettos.
4/25
5/25
Morrison set the chassis up to accept Jason’s mill of a choice: a 620-horse 572 big-block direct from Chevrolet Performance, with a Holley carb, MSD ignition, and a set of Rewarder headers were added for obvious reasons. Behind the potent V-8 is a six-speed Magnum XL (same as the brute Magnum, just with a single shifter location rather than multiple). With the 4.11 gearset, the six-speed’s 0.50-OD ought to give Jason’s ’55 plenty of leg on the open highway, while still retaining the off-the-line muscle it so deserves.
6/25
7/25
8/25
Exterior-wise, though stock-ish in most respects, the Chevy is of concours-level quality … nice as they come, door handles, trim, and all. The paint is PPG Viper Red and black, applied by Thunder Valley. The interior, however, was put together by Wilson’s Upholstery in nearby Rockmart, Georgia. The all-black pleated leather ensemble is complemented with black cut pile carpet, Flaming River steering wheel, Hurst shifter with “modern” vintage (six-gear) shift ****, restored gauge pod, and Vintage Air A/C unit with custom-mounted control panel.
When asked about the project as a whole, Justin says he regrets “absolutely nothing … just that I didn’t build it sooner! And the best part about it was the first night we got the car running and me and my dad took it down the road about two miles … I was in heaven.”
9/25
PrevNext
1 - 9 OF 16
