Can you disable the daytime running lights?
the high beam light and the daytime driving light are two different lights aren't they?
anyways, you can pull the relay for the daytime lights, but it causes a "service engine soon" light to come on in the message center. you could probably run a couple of wires from the ground and the hot in the relay box to a two position toggle switch and turn them off though.
It depends on what year it is. It's not as simple as pulling a fuse. There is a guy that makes a harness to turn them off, but it's $75. But then again, it depends on your year
http://www.bbengineer.com/cars/impala/store.htm
