Braking System Parts
Old Nov 30, 2010 | 02:42 PM
jrh2363's Avatar
Default Braking System Parts
Hey Guys I have a 83 Monte Carlo SS that trying to bring back to life. I am in need of a brake equalizer. It mounts on the inside of the frame on drivers side front, behind the rear of the wheel. I prefer to keep it as original as possible. Any one have a lead where I might find a NOS one or rebuilt or used one. Any help would be appreciated. Jerry
Old Dec 1, 2010 | 09:00 AM
Sparky-88's Avatar
Jerry,
Is the brake 'equalizer' the same as a brake booster? The booster usually mounts to the driver-side firewall just behind the brake master cylinder. If it is the booster, then almost any local auto parts shop should be able to get one for you, new or rebuilt. Same for the online parts shops (e.g. Auto Parts Warehouse).
Old Dec 2, 2010 | 10:55 AM
biggriggs's Avatar
Nope, the brake equalizer (aka proportioning valve) would be the part that makes sure that the front and rear brake lines are getting the correct pressure relative to each other.
Have you tried checking parts stores or a dealership for this part? I don't imagine that it would be that hard to come by.
Here's what my search came up with. Not sure if that's exactly what you were looking for though, but you should be able to find what you want either way
http://www.speedwaymotors.com/Disc-D...alve,9878.html
http://www.partstrain.com/ShopByDepa...et/MONTE_CARLO
http://www.opgi.com/product.asp?Prod...9&topcatid=108
Old Dec 2, 2010 | 11:39 AM
jrh2363's Avatar
This part mount to inside of frame on underside of car all 4 brake lines come to it plus a line from master cylinder and 1 wire comes to it its L shaped dealers say discontinued item and parts store ons wont work prrfer to find if possible as string to restore car Thanks Jerry
Lady Starstruck
Nov 23, 2014 07:47 AM
MJClemm
Mar 16, 2012 10:49 AM
boakesb
Jun 19, 2007 03:29 PM
White05LT
Dec 16, 2006 09:54 PM
Phos187
Oct 2, 2006 10:37 PM
