Antenna
Old Aug 28, 2006 | 09:08 AM
rpd709's Avatar
Default Antenna
Hello,
Just bought a 04 Monte Carlo SS and noticed that it is missing the antenna on the top back drivers side glass. I located the antenna in the trunk but apparently the sticky stuff wore off or whatever and its not on there now... What purpose does that antenna serve.
I pick up alot of FM radio stations some of which are far out without it so I guess its not an FM Radio antenna
or
Could it be the onstar antenna?
and
If so I would like to put it back on what do I need to get to put it back on the glass without making a mess.
Old Aug 28, 2006 | 05:18 PM
Bigg J's Avatar
Default RE: Antenna
Those can be easily stuck on with a good quality automotive double-sided tape. 3M makes a bunch of them.
Not sure of the purpose. My '05 doesn't have that type of antenna, but it wouldn't be the Onstar I imagine.
Old Aug 28, 2006 | 06:50 PM
DESS03's Avatar
Default RE: Antenna
actually it is the onstar antenna onstar works throught the verizon cellular network
Old Aug 29, 2006 | 04:40 AM
Bigg J's Avatar
Default RE: Antenna
Interesting. I wondered how the car communicates with the satellite. Did they change the setup for the later years or something? All I have on my car is that one sharkfin antenna on the roof (I don't have an XM-equipped vehicle, either).
Old Aug 29, 2006 | 11:23 PM
Yellow_Monte's Avatar
Default RE: Antenna
Weird, my 2002 doesn't have any antenna what so ever. I still get perfect radio and everything.
Old Aug 30, 2006 | 04:48 PM
Bigg J's Avatar
Default RE: Antenna
Huh...your right. I never noticed that before. That is wierd.
Old Aug 30, 2006 | 09:42 PM
DESS03's Avatar
Default RE: Antenna
your radio antenna is built into the rear glass and on the newer cars the xm and onstar are built into the same antenna because onstar went digital instead of analog like it was b4
Old Aug 31, 2006 | 02:41 AM
Bigg J's Avatar
Default RE: Antenna
Ohhhhh...Thanks for shedding some light, Dess.
Old Sep 24, 2006 | 02:08 PM
rpd709's Avatar
Default RE: Antenna
I went to autozone to try to find some double sided tape to fit the square piece to attach it to the glass and didn't have any luck... All they had was the strips of double side tape..
Any suggestions?
Old Sep 24, 2006 | 03:11 PM
montejass's Avatar
Default RE: Antenna
Try Home Depot or any similar hardware store.
