All in the name of working Air Conditioning!
Old 04-28-2012, 09:10 PM
HVAC module back together. Next task, put BACK into Monte!!! Ladies and Gentlemen, this is the GOOD phase, re-assembly!
BTW - For those who can see it, there are two types of screws (factory brass looking ones and other silver-ish ones I had to add to compensate for not having the heat stakes anymore).
Attached Thumbnails All in the name of working Air Conditioning!-img_5993.jpg   All in the name of working Air Conditioning!-img_5994.jpg
  #32
Old 04-28-2012, 10:45 PM
Looking good! Should be a nice day to get that sucker in tomorrow.
  #33
Old 04-29-2012, 06:30 AM
I really hope this fixes it
  #34
Old 04-29-2012, 06:54 AM
Franks 03SS's Avatar
2011 Monte Of The Year
Geezz That looks like fun Jason! Lol
Hopefully that fixes your problem man
  #35
Old 04-29-2012, 11:33 AM
I'm hoping it fixes this problem two and that I never have to see this much of the HVAC module again!!
BTW - I noticed on of the flappers for the dual climate control was rather "stiff" if you tried to adjust it by hand, but the other one was SUPER easy. Since I had this apart, I found out why it was so stiff. part of it was rubbing against the housing. I took some sand paper and VERY lightly sanded it until it felt like it moved as easy as the other. I also cleaned the shafts/hinge points for the flappers and applied a very thin tough of Vaseline (for lack of a better lubricant). I did all that to try and ward off potential failing actuators. Sadly, I did not grab pictures of that area (I just now thought about it).
Anycase, I am going to change and head out to begin putting the Monte BACK together!
  #36
Old 04-29-2012, 04:54 PM
Well, on delay. Tried to seat the HVAC module into the car and it's a fight to get things lined up. One of the studs I had to epoxy (broke on removal) broke again! Tuesday, I will have a friend who's done this before give me a hand.
Also, I want to shoot ACDelco. I bought the Evap core seal kit. The evap core connects to a thermal expansion module and has 2 tubes going into it with 2 different size connections. The ACDelco seal kit contains two of ONE size seal (which would fit both sides of the thermal expansion module). UGH! SO now I need another item (I'm going to have my dad stop at the dealership, as I drove to 3 parts stores and NO ONE had it).
  #37
Old 05-01-2012, 08:14 PM
Thanks to the help of my GM Guru and his son, the HVAC module is seated BACK into the Monte!! Truly amazing, they came over and first try seated the silly thing, all I did was watch from the engine side of the firewall to see if the bolts were lining up. They made it look so easy, I kinda feel bad that I called the big guns out on this one!
Anycase, the good news, dash re-assembly to continue later this week!
  #38
Old 05-01-2012, 08:29 PM
Great news, sometimes a second set of eyes really helps.........
  #39
Old 05-02-2012, 08:32 AM
LOL, don't you hate when something looks so hard and then someone does it with ease?
  #40
Old 05-02-2012, 08:10 PM
Well, the Monte is slowly moving along. Aluminum dash cross brace is seated and a hand full of bolts and wiring are in place (I think it's about half way done with this step). Sadly, any pics would be a little anti-climactic since they are dis-assembly in reverse.
Quick Reply: All in the name of working Air Conditioning!
