86 monte really that slow?
Old Jun 30, 2006 | 07:42 PM
86monte818's Avatar
Default RE: 86 monte really that slow?
ouch 150hp its enough for brake stands. but i guess i will have to swap in a 350 good thing theres few wires to swap over. do the motor mounts even have to be changed or is it a direct bolt in swap just unbolt the old motor and put in the new one. good thing 350's are cheap around here.
Old Jul 1, 2006 | 11:48 AM
FORD's Avatar
I guess monte84 will have to find a 350 CUI for his, thats a real let down than the non-SS puts out only 150hp. Doesn't sound like the 305 is worth trying to get anymore power out of.
Old Jul 1, 2006 | 01:09 PM
85_SS's Avatar
ORIGINAL: FORD
You can upgrade and wake up the 305 quite nicely, but the same money spent on a 350 will bring more return. This is why I suggest upgrades that can be swapped over to a 350 should he ever go that route.
Old Jul 1, 2006 | 03:27 PM
86monte818's Avatar
yeah he's right i have write ups on how to build a 345hp 305 they say exactly what parts to use and all. but i probably will just end up swapping in a 350 or that pontiac 400 small block.
Old Jul 2, 2006 | 10:08 PM
86monte818's Avatar
what is the correct timing for an 86 monte carlo ls with the 305 in it. and can anyone show me a picture of where the timing marks are on a this motor. I think if the timing were correct and i did a tune with new plugs/wires/distributor cap/rotor and changed the oil the car should be able to smoke the tires it has off the line and then some. I think with the car is supposed to have more power for more of these.
[IMG][/IMG]
[IMG][/IMG]
Old Jul 3, 2006 | 03:40 AM
85_SS's Avatar
Stock timing for an LG4 is 0 degrees, L69 is 6' BTDC. Timing tab is on the timing cover - you have to look from above behind the waterpump - its a bad location. See here for details:
http://www.montecarloss.com/SS_FAQ_4.html#6
In good tune, an LG4 can still spin the tires no problem with just hitting the gas from a stop. My parents 87 Cutlass had plenty of power enough to get out of its own way with an LG4.
Old Jul 3, 2006 | 07:48 AM
86monte818's Avatar
well im guessing that after sitting outdoors uncovered for 2-3 yrs, my monte carlo isn't in the best tune. so im hoping after doing a high performance tune up, timing it, and changing the oil in the motor, transmission and adding a shift kit, the car will be much more responsive and i will have to try to not make the tires spin when i floor it from a stop, which currently isn't very often due to nothing happening except watching my gas gauge move towards E.
oh thanks for your help once again
Old Jul 5, 2006 | 10:42 AM
monte84's Avatar
i wonder what a new chev 350 would go for?
Old Jul 7, 2006 | 03:36 PM
86monte818's Avatar
a new 350 crate motor cost about 1359 from jegs.com and has 260hp
Old Jul 7, 2006 | 03:48 PM
montejass's Avatar
Check out ebay too....... They have engines of all kinds up for grabs from stockers to all out blown...
