How to get my Monte's acceleration faster
x2... can't tell if you're joking or trolling but anyways..
there's probably 200 threads on what to do...
Throttle Body
Intake
Ubend Delete
Top-Swap
Turbo..
need I go further?
Throttle Body
Intake
Ubend Delete
Top-Swap
Turbo..
need I go further?
Seriously tho go read the link below
https://montecarloforum.com/forum/en...-bumpin-24896/
Not doing anything to engine you can go with diff drive ratio on transmission. Cant remember where I saw it but I saw a kit that changes the ratio from 2.93 to 3.26 or 3.93. If it works same as it does on rear axle on a old car going with either of those will increase accel but hurt mpg.
Plus tearing down a trans isn't somthing amatures should be trying to do
Intake, Rockers, New Springs, Downpipe, Tune with higher shift points.
DONE.
Also stop launching your car in a "gear", put it in Drive and keep in that way. If you feel the want to "shift" your automatic then you need a tune.
DONE.
